603,999 active members*
3,979 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Mastercam post needed for Power Path 15 CNC Lathe DX-32
    Jun 2007
    65
    Does anyone have a clean Mastercam post for a Bridgeport Power Path 15 CNC Lathe DX-32 control?
    Feb 2005
    154
    Post
    Hi Larry,
    I can't help you with the Mastercam post. If you are stuck you could run it in Fanuc mode. Hit F5 for setup and it will give you the option of running in Bridgeport mode or Fanuc mode. The Fanuc mode is supposed to be the same as a Fanuc OT control. I haven't tried this yet. I just got one of these a couple of weeks ago and haven't got it going yet. Might be worth a try.
    Pete
    Jun 2007
    65
    I'm sorry. I should have stated a post to output Fanuc code. We have a couple and they work they are just not clean and we have to do a little editing each time and the threading info is never right.
  1. Mastercam to Galil Post processor needed
    By bbutcher85710 in forum Post Processors for MC
    Last Post: 01-11-2015, 03:40 PM
  2. puma 240 mastercam x post needed
    By outcastproducts in forum Daewoo/Doosan
    Last Post: 03-29-2008, 04:40 PM
