603,946 active members*
3,208 visitors online*
IndustryArena Forum > CAM Software > Mastercam > (Mastercam) Program 4th axis contour around rectangular part
Results 1 to 5 of 5
    Jan 2010
    Angry (Mastercam) Program 4th axis contour around rectangular part
    I am new to the forum and would appreciate any help I can get. I will try to describe this the best i can. I have a rectangular shaped hollow part with . 060 wall thickness. I need to make a simple 2d cut around the part with my cutter only entering about .150 deep. This will seperate the part into (2) pieces. The cut contains lines and arcs. I am not that familiar with programming the 4th axis in mastercam, I did get it to run my path and rotate the part, but the tool is not perpendicular to the plane it is cutting.
    Any advise will be very helpful.
    Thank you
    Jan 2006
    4396
    Which Version of Mastercam??
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Dec 2008
    3216
    If programming 3+1 axis ( the 4th axis is positioning only )
    Then your WCS and planes may be the problem
    The WCS for each operation would be the view you have for your TOP view, the C/T planes for each operation, are set to how the tool is to address the part
    ie using the standard mastercam views
    machine the front face ---WCS = TOP, T&C planes = FRONT
    NOTE- the back and bottom standard views will be 180° rotated around Z-axis (upside-down), you will have to create the correct views
    Jan 2010
    I am currently running Mastercam 9.1. In reguards to Supermans response If I am understanding you correctly, I want to run a continuous path around the rectangular part without interupting the cut. So the 4th axis should not start to rotate until in reaches the corner of the part. My attachment shows what i am trying to cut, the cylinder going through the center of the part indicates center of rotation.
    Thank you
    Mar 2005
    988
    It doesn't program that way. 4th axis rotary even for what you're doing will start right away... even from a lead in if you have it. It takes a custom post to move along a plane until a corner is reached for rotary.
    However, you can "cheat" this by seperating the cuts and pasting them after posting. Cut the plane, rotary on the corner, cut next plande, rotary on corner, etc, etc.
    It's just a part..... cutter still goes round and round....
  1. 2d Tabs on contour to hold part in blank
    By metalworkz in forum Dolphin CAD/CAM
    Last Post: 05-29-2013, 11:22 AM
  2. C - Axis Face Contour w/ Mastercam
    By rexster_001 in forum Mastercam
    Last Post: 12-02-2011, 12:36 PM
  3. Contour on Surface. Mastercam 9
    By kram941 in forum Mastercam
    Last Post: 06-25-2009, 05:12 PM
  4. Need help pathing a 5 axis part in MASTERCAM
    By Fixittt in forum Benchtop Machines
    Last Post: 04-08-2009, 04:42 PM
  5. G34 rectangular box key program help
    By Superiorforge in forum G-Code Programing
    Last Post: 09-13-2008, 04:57 PM
