603,387 active members*
2,766 visitors online*
Results 1 to 6 of 6
    Jun 2004
    10
    Mastercam Router Questions
    Does anyone know the approximate pricing for the Mastercam router series of products (entry, reg. and pro)? From what I heard, Mastercam in general may be out of my limited price range. I'm looking for a CNC router package that is set up for large sheets (e.g. 4x8') and that will preferably do tabs and nesting.
    Besides the pricing question, I'm also wondering if any software out there supports round-over and chamfer bit geometry. For instance, running a specified size round-over bit along some of the edges of parts. Any help would be appreciated...
    Mar 2003
    35494
    I'm going to guess around $10,000 and up. You should contact a distributor to be sure. You might want to look at CadCODE, http://www.cadcode.com. It does nesting. Also look at AlphaCAM.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2004
    10
    Thanks for the suggestions. I'll do a little research on the packages you mentioned. BTW, I found out about the price levels for the Mastercam router series:
    Router Entry: $3000
    Router: $5000
    Router Pro: $14000
    Nov 2003
    181
    Ok this is a little off topic but what exactly is nesting? I hear it here and there but I'm not quite sure what it means
    Carl
    Mar 2003
    35494
    Nesting is taking a bunch of parts of different sizes and shapes, and placing tham on your sheet stock in the best possible configuration to best utilize the stock.
    Gerry
    Nov 2003
    181
    Ok, I understand, I've heard of the process before but I didn't know what it was called. I may have to keep this in mind if I apply for a position at one of the boat shops.
    Carl
  1. MasterCam lathe Questions
    By mefull in forum Mastercam
    Last Post: 09-17-2006, 03:38 AM
  2. Questions about JGRO Router
    By ignatz in forum Commercial CNC Wood Routers
    Last Post: 06-02-2005, 04:27 PM
  3. Questions - Micro CNC router?
    By DarkWolf in forum DIY CNC Router Table Machines
    Last Post: 10-22-2004, 03:24 PM
  4. Newbie Question MasterCAM Mill for Router
    By Sanghera in forum Mastercam
    Last Post: 04-28-2004, 04:41 PM
  5. Wood Router Plans questions
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 03-24-2004, 06:09 AM
