587,218 active members*
2,565 visitors online*
    Oct 2009
    59
    Mastercam stl z
    Hello all
    I import stl and create bounding box with solid. After that I use sillouette boundary and then I use toolpaths.
    My problem is when machining the part the z depth is smaller than the bounding box or stock setup gives .
    How to increase the depth of the part when machining?
    May 2010
    132
    Re: Mastercam stl z
    hello, not sure what you mean by increasing the depth of the part? Are you just trying to machine deeper? or change the model itself? Please share the program if you can so i can look at it and see how you created the toolpath with all the options
  1. Replies: 0
    Last Post: 06-27-2016, 05:43 PM
  2. Replies: 4
    Last Post: 07-03-2014, 05:45 PM
  3. Converting Mastercam Files without Mastercam.
    By OutlawMachine in forum Uncategorised CAD Discussion
    Last Post: 04-16-2014, 11:38 PM
  4. Replies: 1
    Last Post: 03-17-2014, 08:49 AM
