587,380 active members*
3,494 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam X4 missing zones in pocket toolpath
Results 1 to 5 of 5
    Jun 2012
    35
    Hi, I'm starting to use X4 (came from X2) and for some reason, when I do pocketing operations and simulate the toolpath some somes appear to be left un-machined, I would appreciate some help as to why is this happening. I attach the mastercam file and jpg of the toolpath simulation. Ironically, I can't upload mastecam files directly, had to zip it. Let me know if you need more info. Thanks.
    Attached Files Attached Files
    May 2004
    4519
    Change the stepover amount.
    Jun 2012
    35
    Thanks, already tried with everything from 1 - 99% steppover, also every pattern: zigzag, parallel spiral, clean corners, true spiral, and it will always leave something behind, specially in the two "corners" where the arc meets the outside contour.
    Dec 2008
    3126
    Try turning OFF the "Finish" component for the pocketing ( or leave only a small amount, say 5-10% of the cutter base diameter) - this may be what is stuffing you around.
    Roughing stepover, say 50-70%, use the clean corners strategy, ( or try the hi-speed one on the far right ( it may be hiding ), this one adds radii on the inner corners of the toolpath to make the it smoother ( easier on the cutter ).
    Jun 2012
    35
    thanks
    you really are super... man! Turning off the finishing pass did the trick, now there are a 4 or 5 strategies that work perfectly, including the highspeed one, some even are close enough to a finished look so I will probably skip that. Thanks a lot, have a great day.
  1. Missing Y-commands in 4axis toolpath?
    By LN-JET in forum Rhinocam
    Last Post: 08-16-2012, 03:52 AM
  2. Mastercam neck pocket toolpath
    By jimmiethekid in forum Musical Instrument Design and Construction
    Last Post: 05-23-2010, 12:02 AM
  3. Pocket Toolpath
    By jcnewbie in forum Mastercam
    Last Post: 10-21-2009, 07:16 AM
  4. Replies: 10
    Last Post: 12-03-2007, 04:47 PM
  5. changing mill pocket toolpath to lathe-v9
    By scolee in forum Mastercam
    Last Post: 03-25-2007, 03:39 PM
