603,858 active members*
4,446 visitors online*
    Oct 2011
    39
    Material Spec's
    Hello,
    We at our shop are having a problem getting a straight answer with our steel supply company's when it comes to Rockwell Hardness testing.
    We are trying to find some 4140/4150 PH that test in the RC of 40-45. Our mills are telling us that it only should test in the range of 32-36 RC.
    Could someone please inform me on what material we need to order to get the correct stuff.
    Chris
    Apr 2006
    3206
    Quote Originally Posted by cbrannam View Post
    Hello,
    Chris
    4140 PH, 4140 HT DCF Decarb Free, PreHard Quenched Tempered. Precision Grinding.
  1. M75X1.5 -6H spec??
    By david rendon in forum Mechanical Calculations/Engineering Design
    Last Post: 12-08-2012, 08:45 PM
  2. Help with material purchasing. Should I base my dimensions on the material available?
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2012, 07:10 PM
  3. Level Spec
    By behindpropeller in forum Haas Mills
    Last Post: 05-16-2011, 04:50 PM
  4. Computer Spec?
    By TURNER in forum OneCNC
    Last Post: 02-08-2011, 05:55 AM
  5. Steel Spec.
    By ozzie34231 in forum MetalWork Discussion
    Last Post: 07-13-2009, 10:23 PM
