588,548 active members*
5,911 visitors online*
Results 1 to 4 of 4
    Jan 2007
    3
    Material strenght question...
    Hello everyone,
    Question for you engineering types:
    Does anybody know the formula for 6061 T6 deflection strenght / max deflection and that for steel tubing? I'm trying to determine how much deflection will 1/2" x 2" aluminum bar deflect over 10" lever arm with ~100N of force max.
    TIA
    Yuriy
    Jun 2004
    20
    The following formula is for a cantilevered beam only. Don't mix units, stick to pounds and inches and your numbers should come out okay.
    Ymax = PL^3/(3EI)
    Where:
    Ymax = Deflection at end of cantilever beam (inches)
    P = Load (pounds)
    L = Length of cantilever beam (inches)
    E = Youngs Modulus of given material(PSI)
    I = Area Moment of Inertia (in^4)
    E for Aluminum = 9.9E6 PSI
    E for Steel= 29.0E6 PSI
    I for a solid rectangular bar: I = (BH^3)/12
    Where:
    B = Width
    H = Height
    I for rectangular tubing: I = (BH^3 - bh^3)/12
    Where:
    B = Outer Width
    H = Outer Height
    b = Inner Width
    h = Inner Height
    Please correct me if I missed anything. Engineers DO make mistakes
    Jan 2007
    3
    Thanks a lot.
    This is what I was looking for
    Regards
    Yuriy
    Sep 2007
    146
    Quote Originally Posted by croosh View Post
    Thanks a lot.
    Regards
    Yuriy
    You can also download "beamboy". Do a google search; an excellent free program to calculate beam deflections. I find it very useful for "back of the envelope" design.
  1. What material is better 304 or 303
    By Joseph Souza in forum Material Machining Solutions
    Last Post: 08-06-2007, 11:26 PM
  2. Y and Z strenght - will this be stong enought?
    By Goose80 in forum DIY CNC Router Table Machines
    Last Post: 12-30-2006, 12:58 AM
  3. Material for lathe bed question
    By jdholbrook in forum Uncategorised MetalWorking Machines
    Last Post: 05-01-2006, 05:05 PM
  4. Strenght vs.
    By MBG in forum Mechanical Calculations/Engineering Design
    Last Post: 07-09-2005, 03:44 PM
  5. Material
    By ryanduc in forum Material Machining Solutions
    Last Post: 01-30-2005, 01:50 AM
