588,542 active members*
4,895 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Matsuura MC 500 V alarm 04.27 z positionning error
Results 1 to 5 of 5
    Apr 2013
    Hello i'm newbie on this website and i'm french (i apologize for my franglish !). Last month i got a matsuura mc 500 v year 1981 with 4 axis. For information, i'm not a professional of metal working, i'm just an amateur ! The CNC controller is a yasnac 3000 G. I'm just finished to install the machine but i have a problem. After i make all the zero axis position in rapid (x,y,z and A) i try to move the axis in MDI mode. I can launch the spindle (s500 m03 for exemple) move the z axis (g00 z-50.) and it's ok. When i move the x, y or A axis, for exemple g00 x20., the x axis move but after 5 seconds an alarm message appear on the cn screen : 04.27 z positionning error. This is the alarm 27 but i don't know how to solve it ! I know since many year the precedent proprietary and he don't know this problem !
    Do you have a solution to solve it ?
    Nov 2007
    364
    O8000
    G21
    G00G17G40G49G52G80G94
    G91G28Z0M9
    G28X0Y0M5
    A0
    G90
    M1
    N1M6T48(127.0MM SIDE FACE STRUT ARM)
    T7M15
    M1
    G00G90A0
    G0G90G55P4X-220.Y158.150G43H48Z100.S1000M03(FACE 0 RH)
    Z16.
    D61(WEAR OFFSET)
    X-207.Y135.650G41
    G1X-113.798F1200.
    Y129.610
    This is from a Yasnac controll MAM from many yrs ago --------edit and hope it helps
    Apr 2013
    Thank you for you reply but i didn't catch all you say ! The code you posted it's a code who initialize the controller to fix the problem or it's just a code to test the machine ? To edit the code in the controller i think i put them an MDI mode or another ? This week i tested to move the x and y axis with G01 (work travel) and it's works find (no problem with the z alarm). Tomorrow (if i will have the time with my children) i will test your code ! Just for information i cry that the controller is yasnac M5 (not 3000 G).
    Nov 2007
    364
    O8000
    G21
    G91G28Z0M9
    G28X0Y0M5
    A0
    G90
    M1
    This is to home the machine to give it a start position
    Goo g90 g54 xo yo will move the machine to a work offset position
    Goo g43 H1 z100.0 is to pick up toll offset for tool number one
    be careful moving in any rapid--------put down to slow rapid speed and learn to pick up offsets from a manual first
    Nov 2007
    364
    C'est à la maison de la machine pour lui donner une position de départ
    Goo g90 g54 xo yo se déplacera la machine à une position décalée de travail
    Goo G43 H1 z100.0 est de ramasser décalage de l'outil numéro un péage
    être attentif se déplaçant dans toute rapide -------- posa pour ralentir la vitesse rapide et apprendre à ramasser des décalages d'un manuel première
  1. Matsuura MC-600V ERROR and ALARM
    By sjuliao in forum Uncategorised MetalWorking Machines
    Last Post: 02-22-2023, 05:41 AM
  2. Matsuura Mc500v seq error/magazine error
    By mc500v in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2020, 04:57 PM
  3. ALARM!! TOOL TABLE ERROR'' MC MATSUURA 510V
    By victorcnc in forum Uncategorised MetalWorking Machines
    Last Post: 05-18-2020, 02:59 PM
  4. help matsuura alarm!!!!!
    By victorcnc in forum CNC Machining Centers
    Last Post: 03-08-2011, 02:07 AM
  5. Matsuura MC-760-DC alarm 61
    By brad63av in forum Uncategorised MetalWorking Machines
    Last Post: 05-15-2008, 06:35 PM
