587,372 active members*
3,829 visitors online*
Results 1 to 10 of 10
    May 2010
    Matsuura MC600 Yasnac MX3
    Not sure if the problems are related but it seems so. We had a failure in the RS232 communications on this machine while sending some programs. The machine ust shut down while it was idle. Now when we reboot it we get an assortment of alarms.
    329: PC CPU ERROR
    327: UNFINISHED PROG GEN
    310: SERVO OFF RESET
    010: TH ERROR
    I was able to clear the 329 and the 010 with a #6014 D7 parameter edit.
    But now I still have
    and have added
    330: E STOP
    Servo off is normal until the second push of power on for this control.
    Any suggestions?
    John
    Mar 2003
    2932
    Here's what I find regarding alarms 310 and 327 in the Maintenance Manual, and the solution for 327 from the Operator's Manual... Good luck.
    Attached Thumbnails Attached Thumbnails MX3 Alarm 310.jpg   MX3 Alarm 327 Remedy.jpg   MX3 Alarm 327 Description.jpg
    May 2010
    Thanks. I did read something about erasing using the 999 but didn't understand how to input. I will try this in the morning.
    John
    May 2010
    Quote Originally Posted by dcoupar View Post
    So it looks like I was able to clear all the alarms except.
    330 : E STOP
    310 : SERVO OFF RESET
    310 is normal. The 330 is only there when e stop is pressed. But now it won't go away with the switch in either position.
    John
    May 2010
    Quote Originally Posted by TheBigJW View Post
    330 : E STOP
    John
    Anyone have any suggestions where to find info or where to look for an estop error? Is it a parameter problem?
    John
    May 2010
    John
    Duh.
    If anyone else ever finds this in a search. Check the spindle chiller for alarms.
    Not sure if the problem started there but it ended there?
    John
    Feb 2007
    23
    Matsuura RA1 yasnac control MX3 maintenance manual
    Hi all, I would like to know if someone have this manual and is able to sell a copy or if you have information about where can I get it.
    Because I have some issues with this machine recently acquire on eBay.
    Marco
    May 2010
    Quote Originally Posted by marcov View Post
    Marco
    Did you check that the machine is phased right?
    These alarms look a lot like out of phase.
    Try just swapping two of the wires coming into the machine and fire it back up.
    John
    Feb 2007
    23
    John
    Hi John I verify the phases and also did the same.
    Thanks anyway.
    Marco
    Aug 2003
    21
    Hello Marco,
    We had a problem with E-stop when installed our Matsuura MC-760 MX3 machine.
    There is an electrical circuit connecting all parts of the machine that can break the circuit if there is a failure. (e.g. E-stop button on the panel, spindle oil cooling unit, e.t.c.). The last one was a cause of failure in our case, so we added some oil in the spindle and it solved the problem.
    I am not sure that the diagrams for 600 and 760 machines is alike, so
    you should find an electric diagram for your machine, find this circuit and follow it from start to end.
    Maybe you'll find at least what is causing the trouble.
    Igor
    With kindest regards, Igor Kozlov
  1. yasnac mx1 on matsuura programming help needed
    By Brian FRF in forum G-Code Programing
    Last Post: 07-29-2015, 03:09 AM
  2. G70, Yasnac Controller, on Matsuura
    By Brian FRF in forum Uncategorised MetalWorking Machines
    Last Post: 08-16-2010, 06:12 PM
  3. Matsuura Mill With yasnac controll, overload in x axis on rapid.
    By blakemachine in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-04-2010, 02:45 AM
  4. yasnac mx1 on matsuura programming help needed
    Last Post: 08-04-2009, 07:57 PM
  5. Yasnac/Matsuura parameter specifying Z? HELP!!
    By arobustus in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-16-2008, 09:28 PM
