603,839 active members*
4,183 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Matt's Grizzly G0602 CNC Conversion
Page 11 of 12 9101112
Results 201 to 220 of 235
  1. #201
    Jul 2005
    163
    Re: Matt's Grizzly G0602 CNC Conversion
    According to Centroid, you do need to run 1:1 on the spindle vs. encoder. They suggest a minimum of 2000 lines/rev (8000 cpt with quadrature).
    I have several lathe projects in the future, and Acorn seems like the best low(er) cost solution - I'm with you on the software and hardware being from the same company! The encoder support, etc all work to make it superior. With the price increase on Jan 3rd, 2018, I'm buying 2 more (already ordered one).
  2. #202
    May 2011
    308
    Quote Originally Posted by DSpeck View Post
    Ok I better buy another....
    Dang no multiplier for the encoder yet? You wouldn’t think that would be that hard for them to implement?
  3. #203
    Jun 2004
    6618
    Has anyone tried the acorn n a CNCRP plug and play box?
    I am still have intermittent issues with Mach 3 and smooth stepper, so I would like to move away from that.
    Mine also has the plug and play spindle kit, so that is one of the main areas of concern for me. I know acorn can do analog outputs.
    Lee
  4. #204
    I just bought 2 Acorns for my Lathe and mill with Pro. Goodby Mach3 Some of the guys have been having good luck with these encoders found on Ebay $25. OMRON Rotary Encoder E6B2-CWZ1X E6B2CWZ1X 2000P/R new in box free ship.
    I bought a couple to try myself. They are knock offs for sure. You have to run 1 to 1 with the spindle with Acorn. Mine should be here Wednesday fingers crossed. Can't wait to hook them up and take them for a test ride.
  5. #205
    Jun 2004
    6618
    I did order one for the router along with the Pro software.
    I will start a thread to document the changes I make to the CRP plug and play system.
    Should be pretty straight forward. I did not notice any head scratching parts yet.
    Lee
  6. #206
    May 2011
    308
    Quote Originally Posted by Roadstercycle View Post
    Thanks, I ordered one of the encoders from EBay. Can’t beat $25 shipped!
    Man this guy did an amazing job documenting his build. Here is his 1:1 encoder drive.
    Logan CNC Lathe Conversion
  7. #207
    I saw that the other day, he did a really great job. The encoder mount is over the top, $500 mount for a $25 encoder. Actually he had an encoder in stock. It's a beautiful thing. I ordered my pulleys last night for the lathe. I already did the mill encoder mount on the spindle. Next is the lathe. Hopefully by next weekend I'll have them both up and running with Acorn.
  8. #208
    May 2011
    308
    This is a pretty awesome home feature!!!
    Should be able to power off for the night and re-start without need to touch off.
    https://youtu.be/l1xUtRwN6T0
  9. #209
    May 2011
    308
    I had two acorn boards show up in the last couple of days. Dragged the lathe out, dusted it off, cleaned it up and fired up Mach one last time. Everything checked out fine. Ran pretty quiet, now I am second guessing if I should build a second controller....Screw it I will just use this controller.
    Attachment 383848
    Attachment 383850
    Attachment 383852
  10. #210
    May 2011
    308
    Pulled the original CNC4PC boards from the controller. Left the power controls and 5056 stepper drivers. Moved the drivers over on the mounting plate to give a little more room for the Acorn board in the controller. Got the Acorn board mounted on standoffs. Mounted and wired the Centroid 24V PS. After about 4 hours of messing around I had Z and X axis moving around. I had to reverse the X motor direction. I did that by reversing both pairs of stepper motor wires at the driver. I am trying to keep the Centroid settings close to default if possible. Another couple of hours and I had Z and X calibrated under .001' and backlash set. I used .001" for both Z and X. Its amazingly close at the moment. Now on to the VFD wiring. Upgrading from an existing Mach setup is sooooooo much easier than doing this controller from scratch. Actually its pretty fun because it moves along so quickly. So much less troubleshooting. Also Centroid provides all kinds of schmatics to help with various configurations. Its helping me a lot to understand proper implementation of the various safety and interlock systems we often over look on home CNC builds. I built a dedicated WIN10 machine from a 5 year old game machine I had laying around. Plenty of performance. Did a fresh install of WIN10 and configured the OS per centroids recommendations. So far the solid seems much more polished than Mach although I am going to do my best to not talk negatively about Mach. I got us where we are today and made a huge impact on the CNC world. I really appreciate the clean and uncluttered look of the Centroid software interface so far. It really has a professional / commercial feel to it.
  11. #211
    May 2011
    308
    Here is the new layout with the Acorn Board. I will clean up the wiring after I get a few more things completed like the VFD and spindle encoder. I plan to add a proper ESTOP circuit per Centtoid specs, home flags, limit switches, a 4th wire for the 240V circuit. Flood coolant relay. Led enclosure lighting.
  12. #212
    May 2011
    308
    Making some progress. The steppers and spindle are moving around. I finally got the Acorn Board controlling the TECO VFD FWD, STOP, REV AND SPEED.
    https://youtu.be/66jKgjCZul0
  13. #213
    Jun 2004
    6618
    Looking good.
    I have only been doing some preliminary prep research to get everything together for my Acorn on a CRP router. Things like wiring diagrams I will need. Post processor for Fusion 360 for the Centroid.
    Getting the computer setup, etc.
    Then I will be right behind you.
    Lee
  14. #214
    May 2007
    9
    Hi Matt,
    I have been following along with this build as I am getting ready to CNC a G0602 and a G0762. At first I thought I was going to use Mach, as that is what I currently use on my CNC router. After reading through this thread, I'm seriously considering the Acorn/Centroid setup.
    I've been reading several threads and might have them confused, but did you add a braking resistor to the Teco?
    Tron
  15. #215
    May 2011
    308
    Quote Originally Posted by TronCarter View Post
    Hi Matt,
    Tron
    From what I remember, the TECO VFD will not connect to an external braking resistor directly. It needs an optional external braking module. That being said there is an internal resistor built into the TECO VFD you can use, it’s just pretty easy to overwhelm it at the higher RPM’s.
  16. #216
    May 2011
    308
    I have been making some progress on the Acorn encoder setup. I have attached some photos.
  17. #217
    May 2011
    308
    Using only one drive gear, I couldn’t get the encoder close enough to the original spindle gear drive with out it hitting the spindle pulleys. So I added an idler gear to get additional clearance around the pulley. The red anodizing is just some scrap aluminum I had laying around. This may not be the final version of the encoder mount. I have a few changes I will probably make although this should work as is.
  18. #218
    May 2011
    308
    The gears are machined out of white UHMW on the mill using a 3/8 EM 3 FL, 1/8 EM 2 FL and 1/16 EM 2 FL. I used coolant, they came out pretty clean and fit the original spindle gear perfectly.
  19. #219
    May 2011
    308
    The new Centroid wireless remote jpg handle showed up today. I upgraded to the latest software/firmware per the YouTube video. The jog handle works great so far and the quality of it exceeded my expectations!!! It’s so much nicer than the Vista CNC unit I was using with Mach. Nice thick rubber molding on the outside. The jog wheel feels great. Two big thumbs up!!!
  20. #220
    May 2007
    9
    Quote Originally Posted by Turbo442 View Post
    Yes, I was talking about the external braking module. I was wondering if you purchased one and are using it.
  1. Grizzly G0602 10" x 22" Lathe Conversion
    By derekbackus in forum Vertical Mill, Lathe Project Log
    Last Post: 01-29-2019, 09:29 PM
  2. King 10x22/Grizzly G0602 CNC conversion with full enclosure
    By ZincBoy in forum Vertical Mill, Lathe Project Log
    Last Post: 01-16-2013, 08:35 PM
  3. Grizzly's G0602 10x22 Lathe
    By cobmachine in forum Benchtop Machines
    Last Post: 02-01-2011, 03:26 AM
  4. Grizzly G0602 10x22 Lathe Conversion
    By Steelpolish in forum Vertical Mill, Lathe Project Log
    Last Post: 01-21-2011, 11:04 AM
  5. About to pull the trigger on a Grizzly G0602
    By akschu in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2008, 09:36 PM
