603,936 active members*
2,241 visitors online*
    Apr 2020
    15
    maxMasterSlaveDistance question
    I am setting up the cnc760 on an Avid cnc.
    My machine has begun showing a message about the master slave distance being violated.
    During setup operations, it was previously ok.
    The variable allows a 0-100 setting. I presume I need a higher setting. What are the units, and how do I get it set higher than 100?
    I tried changing it in the server.ini file, to no avail.
    Apr 2020
    15
    Re: maxMasterSlaveDistance question
    This is resolved. I had implemented this advice:
    https://support.edingcnc.com/support...s-are-not-zero
    I had added a " G53 G0 Y5" type of line in each subroutine. In doing so it had messed up the Y tandem axis logic, and consistently failed. I removed these lines of code from macro.cnc, it is back to normal.
    That said, when I start it says the axis are not within limit, and I move them with keyboard once. Maybe there is a way of resolving this warning, but for now, it's not a big deal.
  1. Question on spoilboard attachement- Question
    By bonesbr549 in forum Avid CNC
    Last Post: 02-20-2017, 04:45 PM
