hi averby....it does appear that maxnc changed their desibg on the nwer version maxnc 10..my older one has made in USA larger 75mm nema 23 stepper motors..ive seen other maxnc 10 with the smaller made in japan/china 50mm version..so obviously mine will have more torque/power so thats a good thing..as i have always said quality wise ..newer is not always better
well its been a bit of a retro headache but so far so good i was able to save the maxnc file folder from the old desktop pc onto a floppy disk and then put it on my old laptop
surprisingly all i did was hook up the maxnc parallel port cable to my laptop and powered on the maxnc and then ran the "initialize" timeset program per manual and it made a bunch of crazy odd sounds for about 5 min and then said complete
i then just opened the max program and jog mode and bam..the machine actually jogged in x y and z....may have to oil the screw drives a bit but none are bound up just a tiny bit rough...but that could be due to i used default motor setting i may mess around with the settings which may smooth out the xyz movement...i ended up cahnging some of the paramrteter settings and now they motors turning much smoother...
im sure more fine tuning will be needed but for now is ok.
im very happy so far...i think it was a good investment and now with little to no risk since machine seems to work fine
the orig manual instructions has helped out a lot
does anyone know if the drive nuts are made of plastic or metal? and should i oil the drive screws? if nuts are plastic i would think oiling is not advised?
