Hopefully this thread will deter others from buying from MAXNC.
This machine has been down more than it has run. I have sent the controller to the factory once to look at it, still it has cost me more time, frustration and wasted money than any product I have ever owned. Unfortunately, I am stuck with it until I can get my product off the ground.
The basic problem is that the motors stop running all the time for some reason. I have speen hundreds of hours trying to solve it, the company says that I must be doing something wrong. I will not ever in a million years use their dos like software, which they claim is the only way to run it suposedly. I use MACH3, and I have verified that there are signals hitting the controller, even though various axis' just stop all the time. Now the machine will not even run for a minute without stopping. I have swapped out micros, mosfets with known working ones. There are other parts I have not replaced yet, but after 6 hours tonight just trying to cut one simple part, I have finally had enough and now am in serach of a controller that may retrofit right onto this machine. Sending the controller back to MAX will take over a week, plus lots in fast shipping, not too mention, I have tried that route before. They simply do not care to solve this machines problems. They will not return calls, or emails. When you call them you are like a great imposition on them.
Is there a Gecko or other controller that will interface easily? This machine has encoders and is closed loop, but at this point I just need it to run, period, encoders or not. The machine is quadreature, has lin engineering nema23 motors. I need something as fast as possible to get up and running. Thanks in advance if you have a controller to suggest that I can connect up.
