588,130 active members*
5,337 visitors online*
    Oct 2010
    Mazak 640 t fusion Parameters
    We replaced our hard drive, old one currupted. Had to manually put parameters back in ( user and machine) Need access to spindle parameters but cant find its location.
    Mar 2009
    109
    If you replaced only the hard drive, you should not have to reload any parameters because they are held on the control. The hard drive is merely a backup location for parameters. If anything you should be backing up data to the hard drive, not reloading data from it in this case.
    Why do you need the spindle parameters?? Do you have any alarms that you did not mention?
  1. Mazak Fusion 640 T Keyboard
    By fbergski in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-15-2022, 07:18 AM
  2. fusion mazak mill
    By wireguy in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-01-2014, 02:48 AM
  3. backlash parameters Fusion 64 control
    By birchie in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-16-2008, 04:03 AM
  4. Mazak Fusion Memory
    By Mark18969 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2008, 08:52 PM
  5. Mazak 640 m fusion question
    By nightshift in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-13-2007, 06:50 PM
