603,939 active members*
2,420 visitors online*
    Jan 2007
    Mazak L-1 graphics display
    I'm running a Mazak TX-48 with an L-1 NC unit.
    My problem is the display on the graphics option. As far as I can tell, it doesn't work.
    I've done all the scale settings properly, as far as I know, but with 'nozzle trace' and 'shape erase' nothing happens - except some pixel artifacts that appear around the x and y axis display area of the screen. The work support display will work - but nothing draws over it.
    Is this function able to break in this way? Is there a paramater that might be throwing it off so it doesn't display? Or perhaps there is a physical reason it's not sensing where the nozzle is? The manuals don't mention anything about the technical side of this feature, and we cannot afford mazak support.
    Any help would be greatly appriciated!
    Mar 2005
    4
    Still having the problem, email me at [email protected]. We have one of these units that we are parting out.
    Doug
    616-813-1503
  1. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  2. Haas Graphics Mode - changing display speed?
    By pdoherty in forum Haas Mills
    Last Post: 04-10-2007, 02:57 AM
  3. Graphics
    By danbor004 in forum Fanuc
    Last Post: 04-10-2006, 07:45 PM
  4. Graphics work (RFQ)
    By cncadmin in forum Employment Opportunity
    Last Post: 06-20-2005, 06:34 PM
