587,372 active members*
3,745 visitors online*
    May 2004
    35
    Mazak L Alarm
    I have customer who has a Mazak Laser with L controller. They are trying to setup CNC communications and getting an alarm upon punching out. They tried to call Mazak for help yet no one has called back.
    The alarm is 301 which means nothing to me. If someone has a clue or even a list of alarms codes, please fax it to me @ 619-461-5918.
    Also, any wiring diagram would be helpful too. We have wired the cable up to use hardware flow control but maybe this is related to the alarm?
    Greg Mercurio
    Shop Floor Automations, Inc.
    www.shopfloorautomations.com
    (619) 461-4000 Tel
    Dec 2003
    24223
    Is it a Mitsubishi or Fanuc control? If so do you know what system #?
    For the communication, either Fanuc or Mitsubishi, if they have brought the communication out to a 25p D connector then it should Be standard RS232 and you can jumper the handshake out both ends 4-5 6-8-20.
    I am not familier with the Mazak laser so this is general information. For e.g. the error 301 on recent Mazak/Mitsubishi is 'single block on' but I doubt if that is the case here.
    Al.
    Albert E.
    May 2004
    35
    It was a cabling issue - the machine did not have the correct jumpers. We sent them a hardware handshake Grizzly Cable and it worked great. Thx for the attempt!
    Greg Mercurio
    (619) 461-4000 Tel
  1. Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1'
    By Haaatschi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2021, 01:33 PM
  2. Mazak 8G M/C,mazatrol eia-t, z axis stuck
    By imwllc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-07-2009, 04:48 PM
  3. Mazak Rotary Turret Switch reBuild
    By Al_The_Man in forum News Announcements
    Last Post: 04-11-2007, 04:21 PM
  4. Probing - Mazak Fusion
    By CFisher in forum Digitizing and Laser Digitizing
    Last Post: 06-08-2005, 05:02 AM
  5. Servo Alarm
    By linesman 71 in forum Haas Mills
    Last Post: 04-29-2005, 02:45 AM
