588,658 active members*
6,091 visitors online*
    Jun 2010
    Question MAZAK Lathe Live Tooling G41 EIA
    I am not able to get cutter comp to work with the live tooling on a Mazak lathe. I am using EIA with a Mazatrol Matrix Nexus control. Do I need a D after the G41? If I do then where do I enter the tool diameter? This is the program I am running.
    N5 (FINISH POCKETS)
    G18 G20 G40 G64 G80 G97 G98 M202
    G28 U0.
    G00 Z7.
    T1111 M08 (1/4 CARBIDE 3FL END MILL STRIGHT LIVE TOOL)
    M201
    M203 S4000
    G00 Z.1 C0.
    G17 UH
    G12.1
    G122.1
    G00 X-3. C0.
    Z.1
    G01 Z-0.25 F25.
    G41 X-2.7764 C0.2236
    G03 X-2.8321 C0.471 R0.15
    X-3.483 C0.1294 R0.5
    X-2.5 C0. R-0.5
    X-2.8706 C-0.483 R-0.5
    X-3.1679 C0.471 R-0.5
    X-3.2236 C0.2236 R0.15
    G00 Z0.1
    X3. C0.
    G01 Z-0.25
    X3.2236 C0.2236
    G03 X3.1679 C0.471 R0.15
    X2.517 C0.1294 R0.5
    X3.5 C0. R-0.5
    X3.1294 C-0.483 R-0.5
    X2.8321 C0.471 R-0.5
    X2.7764 C0.2236 R0.15
    G40 G01 X2.8882 C0.1118
    G00 Z0.1
    G13.1
    G123.1
    M212
    G28 U0.0
    G00 G80 Z7.0
    M202
    M01
    If someone can help I would very thankful
    Dan
    Feb 2006
    992
    Under tooloffset page.
    The best way to learn is trial error.
  1. Replies: 0
    Last Post: 07-28-2010, 01:51 PM
  2. live tooling on a lathe
    By kkronja in forum PTC Pro/Manufacture
    Last Post: 03-12-2010, 07:13 AM
  3. Mazak Live Tooling Rebuild Help
    By Mark18969 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-13-2008, 06:45 PM
  4. Lathe with live tooling
    By baldysm in forum Uncategorised CAM Discussion
    Last Post: 12-27-2007, 05:28 AM
  5. Mazak live tooling feed
    By westirvingcnc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-12-2007, 06:16 AM
