I'm trying to use Edgecam to generate a EIA program for my SQT15. I run into issues when I try to use live tooling on the turret (i.e. end mill to cut a profile). I index the main spindle with G98 M200: C0.0: I then can start the end mill with M203 S2500: But now what? I seem to be missing the correct command for the turret to come to the part and have the part rotate while the cutter is in position. If anyone has a sample program; calling the tool, indexing the spindle, and cutting a hex shape, please post it so I can see what I am missing. I can then modify our post to work! Thanks.
