603,930 active members*
4,154 visitors online*
    Mar 2011
    Mazak m32 programming in the x, z plane?
    I am trying to put a 60 degree angle on a part. It is to be 1.75x3.00. Is there a way to program this using minimal lines in the program. I do not see a k vector to program, just i and j. Can this be done using mazatrol or do I need to manually program this? And what is the best tool to use to do this?
    Oct 2007
    10
    Only manual unit
    Select the plane for cylindrical interpolation
    G18 for XZ
    At power on and reset, milling machine are set in G17 (xy)
    After this K value is avalaible in programing.
    If your controller is too old to access free text in manual unit, just hope you have ISO programm option..
  1. Mazak programming
    By tikj in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-08-2011, 08:00 PM
  2. EIA/ISO programming Mazak AJV
    By MazakAJV in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-18-2011, 12:28 AM
  3. Mazak T2 Programming Help
    By newbi100 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2010, 10:05 PM
  4. construction plane and tool plane
    By nervis1 in forum Mastercam
    Last Post: 11-05-2004, 06:53 AM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
