603,400 active members*
2,353 visitors online*
Results 1 to 10 of 10
    Aug 2005
    5
    Mazak M32 system disk backup
    I wish to make back up copy of Mazatrol M-32 system disk.
    System disk is not readble on PC.Is there any utility to read and make copy of system disk.There is no menu to make a back up from system .
    Another problem i noticed is the Floppy drive used on the controller is not compatible with the standard pc floppy drive(though they appear to be same) .I tried exchanging with with new 1.44 floppy drive and it is not at all reading?
    Thanks in advance for any help and suggestions.
    rgds
    sivaraj
    Apr 2003
    416
    If the disks you have are the same as my Mazak disks, they are formated with a special Mazak system. You can buy software that will run on a pc that will read these disks, but it is expensive. (at least the software I have found)
    A simple utility to copy these disks would be a big help.
    I am currently looking at buying a software package from http://www.solution-ware.com/. It is a CAM package that allows Mazetrol programming from a PC. Has many nice features like generating G-code from the Mazetrol program, Mazetrol printouts, file organization, converting programs from M32 to M2 etc.
    Another package I looked at is Mazak Camware. I don't think this had as many options (Like being able to generate G-code).
    If there are other options, I would like to here about them.
    Bill
    Mar 2005
    988
    wjbzone,
    Check out this from Griffo Brothers. Its another popular one for PC programming in Mazatrol.
    It's just a part..... cutter still goes round and round....
    Sep 2005
    3
    We have an old copy of solution-ware that I use at the shop, it does a nice job of converting the programs from t-plus - t-32 and etc. (same for the mills) I have used it for some programing but not much. It helps alot around the shop, really helps if you have several different types of mazaks in the shop(we do)
    Mar 2006
    34
    you r right shivaraj
    but you can note all the system parameters manually
    Dec 2008
    5
    parameter problem
    Quote Originally Posted by ravin View Post
    hi sir,
    Roshanlal is this side can you tell me how we enter the parameter in mazatrol T-plus.thanks in advance.
    [email protected]
    Nov 2010
    21
    MAZATROL M32
    HI
    I AM RAJENDER FROM DELHI. IT SEEMS THAT YOU HAVE GOOD KNOWLADGE OF MAZAK .I HAVE MAZAK AJV 35/60 WITH MAZATROL M32 CONTROLLER .WE NAEED TO HELP TO RUN THE MACHINE ,ANY SUGGESTION IS APPRECIATED.
    MY ID IS [email protected]
    Regards
    Rajender
    Oct 2017
    5
    Quote Originally Posted by parshad.r View Post
    HI
    Regards
    Rajender
    Mail me your problems to my mail id [email protected]
    Sep 2017
    139
    Re: parameter problem
    @roshanlal For M-PLUS you can manually enter from the hard copy or through RS232 if you have the soft copy
    Nov 2017
    Re: Mazak M32 system disk backup
    hi
    i can
  1. System Floppy disk M32
    By pcreek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-15-2014, 05:06 PM
  2. Eztrak DX system disk
    By astroparts in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2014, 07:03 PM
  3. Mazatrol CAM M2 (CMT) To Mazak Micro Disk HELP
    By wariat in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-17-2012, 02:13 PM
  4. Mazak Micro disk system
    By locky2701 in forum Polls
    Last Post: 05-07-2007, 10:48 PM
  5. M32 System Disk
    By bean79au in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 01:25 PM
