603,884 active members*
5,612 visitors online*
    May 2013
    5
    Post Mazak M32 Tool Offset Table Type
    Hello again forum,
    I want to run the AJV25 machine in EIA/ISO exclusively. Setting the machine tool offset page to Type B (length/wear,dia/wear), and not use any of Mazatrol tool Data at all. I do my programs in EIA/ISO , and can't seem to get the tool offset page under EIA to show the length/wear/diameter/wear table...
    After a lot of hunting the internets and re-reading parameter manual, we have
    F92.4 - Tool diameter comp type A/B. This does not change the screen from A. I want it B, but regardless of setting its not.
    F92.7 - Tool diameter comp in ISO program Fixed/Valid. Couldnt be more confusing. Set it at 0.
    F93.3 - Tool length of tool Data valid in ISO. So I set it to 0 because no tool data.
    F94.5 - Spare tool selection for ISO. Erm I select the tools, so left it at 0.
    Also found this link with pdf instructions but still no luck: http://www.cnczone.com/forums/mazak-...cad-mazak.html
    If someone could shine their expertise on this I would be very thankful!
    May 2013
    5
    Re: Mazak M32 Tool Offset Table Type
    So it would appear this problem is more than parameters...
    Depending which of the two Parameter/Option floppies I load last, I end up with either proper Tool Offset Type B page OR 4th axis displayed/functional. I took pictures and compared parameters after each disk, and the only difference was in the G page, which deals with paper punching.
    Now I am really lost, and anticipate the dreaded 'no recourse' answer.
  1. how to change tool offset memory type on meldas 500?
    By Francois_DCM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-28-2017, 11:33 PM
  2. Acurite MillPwr - can we customise names in the "Tool Type" table ??
    By rayg in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2013, 10:11 PM
  3. Tool offset with work offset
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 06-04-2012, 06:31 PM
  4. Tool offset with work offset
    Last Post: 05-28-2012, 09:52 PM
  5. Mitsubishi Meldas - Switching Tool Offset Page Type
    By avongil in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-18-2008, 08:20 PM
