587,189 active members*
2,719 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Mazak Mazatrol T1 Parts
Results 1 to 12 of 12
    Mar 2005
    73
    Does anyone have a good mazatrol parts supplier?
    Dec 2003
    24223
    What are you looking for, I usually buy from Mitsubishi Chicago.
    Al
    Albert E.
    Mar 2005
    73
    I need a monitor, or a monitor rebuild for starters. I also need a servo amplifier. Have you ever found anyone with a supply of used parts?
    Dec 2003
    24223
    Is the screen dead, or just very dim? As I have just replaced the crt in one Mazak T1 with a crt from an old 12"? monochrome monitor, if this is the case, what I did was seek out somewhere that has old PC monochrome monitors (they are becoming rare, but $5 or $10 ea.) and find a tube with the same phyisical diminsions also the same scan angle, thats the angle of the crt from the screen to the neck. If you feel you don't want to handle the swop yourself, any TV or PC repair shop would do it. Its probabally over $1,000 for a new one, if you can get them.
    Al
    Albert E.
    Mar 2005
    73
    For a little while when you powered it up it would be small and scrambled. You had to cycle the power a couple of times and it would be fine. Well, of course after a few months of this it quit righting itself and now it stays that way. We have other T1 machines, and I swapped it out and it is definitly in the monitor. Then I had to rob a servo amplifier to fix one of the other machines. I may just part this thing out, or sell it all together. It's a quickturn, about a 83 model. I don't know do you have any ideas?
    Sep 2006
    5
    Hello
    My high voltage coil burned out on my QT-15 lathe monitor.
    I want to replace it with old monitor from a computer.
    Do you have the pin out from the Mazak monitor?
    Will an LCD new monitor work?
    Bye
    Tony
    Dec 2003
    24223
    You need a TTL monitor (Old technology) I will try and look the pin out up tomorrow.
    Al.
    Albert E.
    Sep 2006
    5
    Hello
    Thanks for the help
    I think there is a 6 pin white connector
    Bye
    Tony
    Dec 2003
    24223
    What control is it? The pinout I have is for the older monitors, that go to the 20 pin Honda connectors.
    Is it monochrome or colour?
    Al.
    Albert E.
    Sep 2006
    5
    Hi Al
    The control is a T32B
    The connector is a rect. 15 pin. Only 10 pins have wires on them.
    It has an amber screen.
    Bye
    Tony
    Sep 2006
    5
    Hi Al
    Bye
    Tony
    Oct 2005
    162
    the last couple of places i worked for nearly payed for the people to take the parts away.
    On the other hand, You have different fingers.
  1. Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1'
    By Haaatschi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2021, 01:33 PM
  2. Cnc Parts Parts And More Parts
    By berin in forum Community Club House
    Last Post: 07-27-2010, 08:21 PM
  3. RFQ two Aluminum parts, cheap no rush
    By mike_r in forum Employment Opportunity
    Last Post: 04-29-2005, 04:14 AM
  4. Mazak H15 with Mazatrol M2
    By Steve_rb in forum DNC Problems and Solutions
    Last Post: 03-19-2004, 01:27 PM
