588,603 active members*
9,489 visitors online*
    Nov 2006
    925
    Mazak monitor
    As part of the ongoing VQC saga my monitor has packed up.The problem appears to be the FKSV-2-0 power supply card on the side of the C5470NS monitor.Does anyone have a schematic for this card or know the input voltages the monitor requires.
    Mark.
    Jul 2007
    5
    Mazak / Mitsubishi monitors
    You can find new replacment OEM monitors on this site http://www.pennineuk.com/mitsubishi-monitors.htm
    Nov 2006
    925
    Thanks Fanucone.I know of Pennine and all the other names they trade under.I can buy a new monitor from a dozen places in the UK.Cost is anything between £500 and £4000.The monitor was ok,as stated it was the power supply card that had the fault.Two small capacitors fixed it and it is now working.
  1. mazak monitor
    By rhurt in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-19-2022, 10:18 AM
  2. Vf3 Monitor Blackout
    By j-radkemachine in forum Haas Mills
    Last Post: 02-18-2009, 08:05 PM
  3. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  4. Mazak T-Plus Color Monitor Help
    By Jarwalcot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-17-2006, 11:48 PM
  5. Monitor problem
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 02-28-2005, 04:51 PM
