587,189 active members*
2,779 visitors online*
Results 1 to 4 of 4
    Dec 2008
    mazak Quick Turn
    Trying to drill a cross hole
    using the live tooling
    and the hole is not on center
    is there a adjustment?
    Nov 2007
    361
    setting the tool data and tool offsets on a mazak live tooling lathe
    This is the 1st time I have got a chance to set-up a mazak lathe . If it is anyway possiable can you tell me how to set the tool data then the tool offsets. This machine (Mazak 200mt ) has a y axis and I have never used y before can you help me get the tool data set and the offsets?
    Michael
    Feb 2006
    992
    Follow the bottom right handside, and just put physical tool information in tool data. The live tool offset is specification manual(it's only reference) the best way is to indicate the spindle the get that number.
    If you have tool eye ...... it's pieca a cake, all you need is touch off.
    The best way to learn is trial error.
    Jan 2009
    47
    Check with an indicator
    The turret may be off! Place a dial on the holder and wind the axis back and forth. If the turret is out thats your prob. Take out the tapered pins from the face of the turret loosen the cap screws and reset the turret on center by dialing the inside of a boring bar holder with an indicator mounted on the chuck.
  1. Mazak quick turn nexus 250ms 640t control
    By sidecar82 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-24-2012, 08:30 PM
  2. Mazak Quick Turn 15 leaking air?
    By revlimit in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-25-2008, 06:04 PM
  3. Mazak Quick Turn 350
    By T.J in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-10-2008, 12:14 AM
  4. Quick Turn 10 Controller FR-SE
    By Rooster in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-07-2008, 02:05 PM
  5. Mazak Quick Turn 350
    By T.J in forum MetalWork Discussion
    Last Post: 05-14-2008, 12:19 PM
