603,962 active members*
2,984 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Mazak Space Gear 510 MK2 – Z-Gap Height Calibration Out of Spec
Threaded View
AutomationDad Mazak Space Gear 510 MK2 –... 06-16-2025, 04:25 PM
cncmakers001 Re: Mazak Space Gear 510 MK2... 06-17-2025, 03:35 AM
AutomationDad Re: Mazak Space Gear 510 MK2... 06-17-2025, 12:38 PM
    Jun 2025
    4
    Hi all,
    I’m in the process of running a full calibration on our Mazak Space Gear 510 MK2, and I’ve hit a snag that I’m hoping someone can help with.
    According to the Maintenance Manual (Section 10-4: Adjusting the Profiling Unit), there’s a procedure for confirming the Z-gap between the laser head and workpiece. The manual states that the Z-height should read 1.0 mm ± 0.1 mm when the beam is focused properly.
    However, when I complete this process, the machine consistently reports a Z-value of 1.963 mm — which is way out of spec.
    So here are my questions:
    - Why would the Z-gap be reading so far out if the calibration process is being followed exactly as per the manual?
    - What’s the correct way to bring this Z-gap back to 1.0 mm?
    - Is this a case of adjusting the Z-axis offset, or is there another parameter I should be updating?
    Has anyone encountered this before or had to make similar adjustments? Any advice or steps you can share would be much appreciated.
    Thanks in advance!
