588,039 active members*
3,993 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > mazak v-5 w/fanuc 6m control nc fuse light??
    Mar 2005
    21
    ok here goes anyone out there w/a fanuc 6m controller on a mazak v-5
    on mine there are a row of malfunction lights on the front panel
    the first one is labeled "nc fuse" when I turn the control on (front button after side breaker" it powers up fine and then after 20 or so minutes the screen turns off and the nc fuse light comes on.
    this used to be a rare intermittent problen that came up about once a month, but today it decided to start faulting every 10 to 20 minutes.
    the operators manual has this to say "nc fuse alarm" alarm for nc fuse blown out- the display lamp lights if the fuse is blown out-check whether the nc fuse is blown out. if the fuse is not blown out, there is some trouble in the unit.
    no S___ sherlock!
    h btw yes I did check all the fuses in the nc cabinet, and for that matter every fuse I could find on the whole friggen machine. no luck.
    anyway, if one of you has come across this problem your help and experience will be greatly appreciated thanks in advance.
    Dec 2003
    24220
    Do you have a print that shows exacly what the indicator light is monitoring? One thing I would check to see if the DC power supply is OK. It is usually mounted close to the Main board.
    Al.
    Albert E.
    Mar 2005
    21
    thanks al one of my other gurus already rescued me
    the power supply voltage was 4.8 and needed to be turned up to 5.2
    works like a charm now. :idea:
    well so far anyway :fingerscrossed:
  1. mazak v5 micrcenter w/ fanuc 6m b dnc??
    By wild01 in forum DNC Problems and Solutions
    Last Post: 12-24-2010, 02:06 AM
  2. PC input/control with Fanuc 5
    By jevs in forum Fanuc
    Last Post: 10-22-2008, 03:49 AM
  3. Did Anyone hear of "Spectra Light Mill Control"??
    By CNCNR in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2008, 12:28 AM
  4. fanuc tool change prompt light
    By cam in forum DNC Problems and Solutions
    Last Post: 04-02-2004, 03:27 PM
