603,897 active members*
3,515 visitors online*
    Nov 2012
    Question Mazak V7.5 Clamp/Unclamp Issue
    I recently have been setting up a Mazak V7.5 for use in a school metal shop. Everything was going well until the emergency stop got depressed during an automatic tool change. Now I can't even load a tool manually into the spindle. It seems like the hydraulic drawbar mechanism does not open far enough to load the M40 tool holder. System hydraulic pressure is perfect though, and both proximity sensors seem to work fine. I have been stuck on this problem for several days. Does anybody have any possible remedies or solutions to this problem?
    Aug 2008
    292
    maintenance
    Quote Originally Posted by dbrus38 View Post
    usually it requires maintenance to do a mechanical adjustment, although once after a Estop I had a machine that would not home and it required a parameter setting to be reentered AND a guard removed and a mechanical adjustment made.
    ..... a sticking tool holder is 99% of the time a mechanical adjustment or a spring replacement AND a mechanical adjustment
    Apr 2002
    5003
    Have you tried to make a mechanical override of the solenoid valve. Usally all of these parts have a small button to switch them in the other position.
  1. Unclamp/Clamp on yasnac lx3
    By Delw in forum Uncategorised MetalWorking Machines
    Last Post: 10-19-2018, 11:22 AM
  2. Tool clamp/unclamp via Focas
    By Danijel in forum Fanuc
    Last Post: 01-14-2011, 08:43 AM
  3. VM1 spindle clamp/unclamp error
    By BSF in forum HURCO
    Last Post: 02-15-2010, 02:19 PM
  4. Clamp Unclamp Problem VMC
    By 24kilo in forum Fanuc
    Last Post: 01-18-2010, 11:44 PM
  5. clamp and unclamp AB axis in PB command
    By NCexplorer in forum UG NX
    Last Post: 06-10-2009, 03:53 AM
