587,787 active members*
2,442 visitors online*
    Jun 2017
    8
    mazak vcn 530c
    Hi
    I need some help with my mazak vcn 530c with smooth control, I'm milling a large and long piece of steel, it is so long it has to stick out of the machine . Then I get a problem with tool switching. When I make a tool switch, the machine puts itself in Y0, but since the material is as wide and long as it is, this is not ideal because it will bang the material into the machine.
    Have found that I have to do something in the parameter list, have to change parameter numbers in RB19, but have done so, but the machine is still in Y0, talked to the vendor of the machine but did not get any wiser
    Do any of you have any ideas?
    Jun 2017
    Re: mazak vcn 530c
    After modify RB19, you need to change M6 to location for Y.
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Mazak VCN 530C vs Mazak VCS 530C
    By JeremyMinnesota in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-29-2013, 09:53 PM
  3. Mazak QT-10 T2 manuals --acct w/ mazak?
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2012, 05:09 AM
  4. Mazak 6pc with machine Mazak 400n
    By anva in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-17-2010, 08:30 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
