603,390 active members*
3,098 visitors online*
    Oct 2005
    420
    Mazak VQC-20/40B - X axis ball screw removal
    Wondering if anyone on here has ever replaced the ball screw on the X axis of a VQC-20/40B. I have new thrust bearings to install but am thinking I may as well send the screw out for rebuilding.
    To the best of my knowledge it is the original and never been touched. Both X and Y are noisy and backlash is becoming an issue (same with Y). Hate to go thru the work to replace thrust bearings but not touch the screws.
    On the X, would I have to remove the table or could I gain access to the necessary mounting bolts from underneath via the chip pan area? I probably wont be attempting this for at least a month but it's something I need to do sooner or later.
    Thanks,
    Nate
    Dec 2011
    18
    Re: Mazak VQC-20/40B - X axis ball screw removal
    hi friends anyone help me about VQC 20/40A or B MAZATROL CAM M-2 control parameter.my machine s battery also dead because it wasnt used 3 months or long i must initialise the sytem but i dont have parameters of this machine.
    is there anyone send me parameters? i will be really appriciated by any help.
  1. Replies: 2
    Last Post: 02-27-2013, 12:56 AM
  2. Takumi V8 Ball Screw Removal
    By rasauber in forum Uncategorised MetalWorking Machines
    Last Post: 10-17-2012, 02:50 PM
  3. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  4. y axis ball screw
    By wayneswagon in forum Fadal
    Last Post: 03-06-2010, 04:54 PM
  5. Ball Screw Removal
    By smarbaga in forum Linear and Rotary Motion
    Last Post: 11-24-2005, 08:56 PM
