587,221 active members*
3,160 visitors online*
    Feb 2007
    5
    Mazak VTC-300C 212 Alarm?
    I came into work this morning and when I turned on the machine and homed it out, I got a "212 Alarm - Magazine Drum Malfunction".
    After a Google search, I found this: "212 is the battery alarm from the magazine drive" but nothing about where the battery is or what kind.
    Anyone know? Thanx in advance!!
    Oh yeah, the control is a Mazatrol 640MN, if that matters...
    Mar 2005
    988
    On a Fusion control, you'll have a MR-J2 drive that probably runs that. The battery is not much different than a FANUC drive battery. On that machine, I'm not sure where the drive is located. I'd check the power cabinet. But on many other machines, a drive(s) is also located elsewhere. For example in the tool change area under a panel or something. Look in you parts book for all of the MR-J2 drives. On the front of the drive, you'll see a couple flip up covers near the top. Behind that is the battery...
    It's just a part..... cutter still goes round and round....
  1. Mazak H-500 Alarm
    By newguy81 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-17-2013, 06:50 PM
  2. Mazak FAN alarm
    By leito1489 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-09-2007, 02:22 AM
  3. shutting down door alarm for mazak t plus
    By scott 54 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-14-2006, 02:27 AM
  4. Mazak alarm code 323. Need help please.
    By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-20-2006, 10:05 PM
  5. Mazak L Alarm
    By SFA in forum DNC Problems and Solutions
    Last Post: 05-26-2005, 06:52 AM
