603,771 active members*
2,697 visitors online*
Results 1 to 12 of 12
    Sep 2023
    18
    Mazak VTC-30C with Mazatrol M-Plus
    Hi!
    I have such problem. In the morning, I turned on the machine, run all axes to the machine zeros and received the error 2 EMERGENCY STOP. I turned off the machine with the rear switch and turned it on again, but the green button on the control panel did not light up. Found that the 24V 120W power supply unit is not working. Disassembled and repaired the 24V power supply, the green power button on the control panel is now light, but the following alarms remain active:
    2 EMERGENCY STOP
    3 EMERGENCY STOP
    382 SPINDLE POWER CUT MALF.
    383 PLC EMERGENCY STOP RELAY FAULT
    385 ESTOP SAFETY RELAY FAULT
    Please help.
    Sep 2023
    18
    Re: Mazak VTC-30C with Mazatrol M-Plus
    Anybody knows anything about this problem? All LEDs are lit or blink green on all units. No red LED
    Sep 2023
    18
    Problem is solved.
    Aug 2009
    1573
    ...what was the problem ?
    Quote Originally Posted by machinehop5 View Post
    Jak rozwi?za? tenproblem?
    Jak by? problem....
    Quote Originally Posted by Foreigner1976 View Post
    Problem is solved.
    Help!!!!
    Hi!
    2 EMERGENCY STOP
    3 EMERGENCY STOP
    Please help.
    Help...
    Sep 2023
    18
    I apologize for the late reply. The reply notification does not work.
    In my case it was a software problem. I performed the memory reset procedure, reinitializing memory and all the errors disappeared, the machine works normally.
    If you do not know how to do this, then I will try to explain this procedure.
    Hello. I encountered the same problem.
    I checked the entire electrical circuit, everything works.
    I can't reset the errors.
    Please tell me how to reset the memory correctly?
    Maybe there is some literature that fully describes this procedure?
    Sep 2023
    18
    This document describes the memory reinitialization procedure.
    Thanks, friend!
    The work is at a standstill, and the equipment is needed.
    I will try, and I will write about the results.
  1. Mazak VTC-30C, Meldas MDS-B - alarm 50
    By rpapis in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-06-2021, 12:14 PM
  2. Mazak VTC 20 B with Mazatrol M-plus control
    By EHRtuning in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-02-2021, 03:05 PM
  3. Mazak VTC-41 Mazatrol EIA
    By skylinkwisp in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-04-2019, 04:47 PM
  4. Mazak VTC-30C Restart not working
    By aminoovitch in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-17-2018, 08:14 PM
  5. Mazak VTC-41 with Mazatrol EIA error
    By trieucn in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-01-2015, 08:32 AM
