588,567 active members*
4,913 visitors online*
    Aug 2007
    10
    Question Mazak VTC-41 w/Mazatrol EIA - No Part Origin
    Hello everybody.
    Well, I've got my first formal job as a NC programmer, although the machine is a little bit outdated. The company I work for owns a Mazak VTC-41 VMC with a Mazatrol EIA control (Yasnac MX3) dated from 1994.
    Now, I'm in a little bit of panic here, not because the machine won't do any moves I instruct it to do, but I'm missing the most fundamental feature in a CNC machine, and I haven't found the answer either by browsing the web or reading the manuals.
    How do I set the part origin?
    My bosses don't know the machine either, they're newcomers to CNC, and I'm more of a "new schooler", meaning that I know only the newest systems (I love Centroid CNC), but the minute I stepped into the machine room and saw the behemoth, I spent a day and a half swimming deep into the manuals and handbooks to no avail.
    Well, the bosses said that in some sort of introductory course they had on the machine they were told that, after the program initialization codes (G21, G0, G40, G49, etc.) they should position the spindle where the part zero is supposed to be, jot down the coords, home the machine and use G92 to set the part zero there, but whenever I try to do that and try to move the machine, it just won't move or will give me wrong coordinates (and readings).
    The control has a button labeled as ORG, and the manual says it's used to set the part zero, although I've tried using it everywhere (ALM, DGN, OFS, SET, POS, and I do mean everywhere) without any results.
    Any help would be super appreciated.
    FGB.
    Aug 2007
    10
    Nevermind
    Well, I just stumbled upon the Parameters Manual at the workshop. My boss has been hiding it so nobody fiddles with the machine. Tweak some parameters here and there, and I made ORG work and set the part zero.
    Duh.
    Thanks for reading.
    FGB.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Changing part orientation/origin
    By SVM in forum BobCad-Cam
    Last Post: 08-20-2007, 08:11 PM
  3. Origin and mazak??
    By Fendertok in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-13-2006, 01:06 AM
  4. Machine home vs part origin question
    By yukonho in forum Mach Software (ArtSoft software)
    Last Post: 01-23-2006, 03:05 PM
  5. Move part origin
    By vertcnc in forum Solidworks
    Last Post: 11-06-2005, 09:15 PM
