587,731 active members*
2,874 visitors online*
    Apr 2006
    825
    Mazaks Camware Rendering Problem
    Hi all,
    Hoping that someone will be able to assist...
    I have just installed Mazak's Camware on a Dell Precision T3500 Win7 (32bit OS) system. (please see attached picture to see the version number)
    Everything seems to work really quite well, communicates to the machine and all, but when the programmer is trying to run a simulation of the toolpath with a rendered view of the action, all we are getting is a bright blue screen with nothing showing up.
    Any movement of the mouse into, across or anything in the display area results in the display reverting to a wireframe view of the current model.
    We can display a rendered image of the chuck and workpiece at any time, but not during simulation.
    Got any ideas as to what settings might be screwing up this display?
    I have downloaded the latest version of the video card drivers.
    Video card is a Nvidia Quadro 2000 with 1GB ram.
    CPU is a Intel Xeon W3565 3.20Ghz 8M Cache 4 core beastie...
    Brian.
    Aug 2006
    62
    I have had problems with CAM systems not rendering thing properly. I have had to switch from an ATI based GPU to nvidia. Unless Mazak updates there software you may need to find a different GPU. Some times the less expensive gaming cards work better than a more expensive one.
    Apr 2006
    825
    Thanks for your reply, sorry for the delay in answering... been off on leave.
    Looks like I will have to try a different video card, thought that might be the solution.
    Damnit!
  1. Part rendering and posting problem
    By Jedi in forum GibbsCAM
    Last Post: 04-21-2011, 03:30 PM
  2. mazaks experts needed (jobs in SE usa)
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 02-20-2011, 08:03 PM
  3. Haas expert, now working with Mazaks
    By tom465 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-25-2010, 05:45 PM
  4. camware tpc problem
    By mcgpz1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-05-2008, 03:41 PM
  5. Esprit DNC any luck with Mazaks?
    By Castle1 in forum Esprit
    Last Post: 10-23-2007, 04:37 PM
