587,657 active members*
9,270 visitors online*
Results 1 to 4 of 4
    Mar 2006
    34
    Mazatrol EIA T zero return
    Hello,
    We received an old Mazak from another workshop which runs fine except that when we zero return in X the turret does not align with the spindle. And each time it may be a little different. Waiting on a replacement EIA and maintenance manuals from MazaK but need to get going. Any ideas on this? Thanks very much.
    Dave Hall.
    Mar 2006
    34
    Hello,
    Correction of earlier post, machine repeats fine on referencing, however the loaded value is out by a few mm. We can see the preset value in the parameters but cannot access them to edit it. Any ideas on how to access parameters on this NC. Thanks very much.
    Dave Hall.
    Feb 2008
    Hello Dave
    I am serching for A programing & operating Maunal for Masatrol EIA Hard copy or copy from A hard copy to purchase. I just bought A mazak VTC-41 came with no Manual's. Sorry I can't help with your problem.
    Bobby Triplett
    Mar 2006
    34
    Hello Bob,
    We sorted the problem out thanks to some good advice. Make a parameter edit then power down and power up again. We had a similar problem with manuals and are waiting on a duplicate set from Japan. Probably best for you to approach Mazak USA. Not cheap but an essential item like tooling.
    regards.. Dave Hall.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Return to start
    By _taz_ in forum DIY CNC Router Table Machines
    Last Post: 12-12-2007, 02:54 PM
  3. return height
    By shepherd in forum BobCad-Cam
    Last Post: 06-20-2007, 06:08 PM
  4. How to fix Zero Return after crash
    By burroughs in forum DNC Problems and Solutions
    Last Post: 03-10-2007, 10:49 AM
  5. Fanuc 18M Z return
    By pinguS in forum Fanuc
    Last Post: 07-27-2006, 03:43 AM
