588,500 active members*
4,951 visitors online*
    Nov 2009
    58
    Mazatrol Help - Tool ID CODE - I don't get it
    Help - I'm not really getting it -
    On a new to me Fusion 640MT for Integrex,
    Is the Tool ID Code (A-Z) the same as the cutting direction on SP1 or SP2?
    If I choose A for all the tools cutting in the same direction on the same spindle, that ID (A) becomes that direction & orientation???
    SO there's no actual defined orentiation for any given letter? You just choose them as you setup?
    OR
    Am I missing some chart that tells me to use (A) for tools in X direction?
    These manuals are really bad - Why do I need to look in 2 or more? manuals to learn tool setting? (rant):drowning:
    Feb 2009
    22
    Your not missing anything -
    In mazatrol its as easy as that.
    Nov 2009
    58
    Thank you jay4389!!!!!!!!!!!!
  1. g-code on my mazatrol machine
    By imwllc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-04-2011, 03:46 PM
  2. Mazatrol Tool Def length Default value
    By epelchat in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-14-2010, 06:17 PM
  3. Mazatrol vs G code
    By PRINT_FX in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-05-2010, 12:44 AM
  4. Help needed Mazatrol M+ tool hieght
    By mt92 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-31-2009, 09:19 PM
  5. Mazatrol M2 Tool settings help
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-06-2008, 09:10 PM
