603,923 active members*
3,821 visitors online*
Results 1 to 5 of 5
    Jan 2008
    27
    Mazatrol M32B DNC option
    Does anyone know how to turn my DNC option on - for
    the Mazatrol M32B
    Aug 2007
    11
    Hi not sure if this is what you want but on an M2 if you hold Auto + F2 at the same time it will switch to EIA mode.
    Jan 2008
    19
    Most Mazak machines communicate using their own proprietary protocol so most simple DNC software won't work. Mazak obviously want you to spend a load of money buying their software and conversational programming tools.
    On many machines you can switch the protocol off and run in standard ISO. On an M32 this would be something like this
    Para#5
    G19 = BaudRate = 2 (4800)
    G20 = StopBits = 3 (2 stopbits)
    G22 = Parity = 0 (Even)
    G23 = DataBits) = 3 (This will switch the Mazak to 8bits but they also count the parity as a bit so set your PC software to 7 bits)
    G24=1
    G25 = 0
    G26 = 0
    G27 = 0
    G28 = 0
    G29 = 3
    Set the PC to 4800, 7bits, Even Parity with RTS/CTS flow control
    Obviously in ISO mode you won't be able to do any offline conversational programming. If you want to do that then you might consider the software from Griffo Bros. I'm not sure of their webiste but of you google for Griffo bros you'll find it. It's not cheap though.
    Jan 2008
    27
    Jan 2008
    27
    I have the mazak data transfer program and cimco. they both can drip feed.
    My mach. says no dnc option. Thanks for you'r reply. I'll look into those params.
    I can load files back and forth and run and save, but some programs are too large for this old beast and I hoped to drip feed with DNC
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. Mazak VTC-16 Mazatol M32b error...All 200 series
    By k8bebop in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-30-2008, 01:04 AM
  3. Generate NC option
    By Doug W in forum Hypermill
    Last Post: 01-15-2008, 04:32 AM
  4. Mazatrol M32B and EMC2
    By iwebcodms in forum LinuxCNC (formerly EMC2)
    Last Post: 11-16-2007, 03:09 AM
  5. Mazak - Mazatrol M32B - 42parameter error
    By rajappa in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-05-2007, 06:17 AM
