587,196 active members*
3,038 visitors online*
Results 1 to 8 of 8
    Sep 2008
    26
    Mazatrol T1/M4 parameters
    We have two Mazak M4 lathes, both built within 6 months of each other. One has different software loaded and the grooving cycles are different. one works fine with MazaCAM, the other has "trash" in the first few lines.
    Does anyone have a solution to getting these two machines to be identical?
    Can the "firmware"/"parameters" off the "favorable" machine be loaded into the other?
    Both have T1 controls. Both run and are in production.
    Thank you
    Dec 2007
    300
    T1 controls come in two flavors. The original T1 and an upgraded version that Mazak called the T1-(Dash) They are completely different hardware and cannot be updated by software versions.
    Sep 2008
    26
    dang... somehow i knew that was going to be the answer...
    ok, why does one like mazacam and the other is cranky with it? any special changes i need to make?
    Dec 2007
    300
    Mazacam cannot create a new T1 program only edit existing ones. As long as you keep them separate they should be ok.
    Sep 2008
    26
    Right.
    What i am needing to know is can a separate "post processor" be made for the oddball machine? for all intents and purposes, the programs can be used on either machine, BUT, one must pay close attention to the trash in the first few lines and the grooving cycles... otherwise, the operator on up to the owner have a really crappy day.
    Sep 2008
    26
    While im thinking about it, do you know of a functioning Mastercam X post that can be used on the T1? i have heard that this is akin to searching for Bigfoot or Nessie...
    Dec 2007
    300
    T1 is Mazatrol only, no g-code input. Remember the T1 has been out of production for over 25 yrs. The first Mazatrol with eia support was T2.
    Sep 2008
    26
    ... i can dream, cant i?
    thank you very much for your help.
  1. Need Parameters Mazatrol T1 Controller.
    By weblogictech in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-16-2020, 08:32 PM
  2. Mazatrol CAM-M2 communication parameters
    By eltorio in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2020, 10:01 AM
  3. Mazatrol M2 parameters
    By pcreek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-16-2017, 06:06 AM
  4. Mazatrol CAM T4 parameters
    By active-precision in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-05-2008, 07:19 PM
  5. Mazatrol T1 communication parameters?
    By sinjin341 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-22-2008, 09:35 PM
