587,207 active members*
2,901 visitors online*
Results 1 to 4 of 4
    Sep 2008
    14
    MDF vs Plywood
    hi
    I'm about to make my first CNC (JGro) mill . I wonder if i can use plywood instead of MDF since i can get the plywood needed for free
    i was thinking about using 18 mm (0.709 inches) for my first mill ..
    have anyone tried to use plywood instead of MDF ?? and will it work ??
    Aug 2005
    578
    Read this post and make you own conclusion... For the first I would say go for it....
    http://www.cnczone.com/forums/showthread.php?t=49251
    Bob
    Sep 2008
    14
    Quote Originally Posted by blackbeard52 View Post
    Bob
    Tanks for the reply it looks like my first will be a plywood mill ..
    it looks like the main problem is wrapping of the plywood if i cut out the pices and seal em with paint BEFOR assembly will that help ??
    i will be using spruce construction plywood ..
    Aug 2005
    578
    Worst case is you will build a machine to build another.... second is much simplier...and Yes it will help to paint it and may be just fine for the purpose you need it for.
    Bob
  1. newbie: plywood or mdf?
    By dandydon in forum DIY CNC Router Table Machines
    Last Post: 12-29-2007, 08:40 AM
  2. best plywood
    By beamer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-06-2007, 11:27 PM
  3. What Bits Do You use For Plywood?
    By Joe Petro in forum DIY CNC Router Table Machines
    Last Post: 02-24-2006, 09:07 PM
  4. Plywood and V Bearings
    By spalm in forum DIY CNC Router Table Machines
    Last Post: 12-09-2005, 03:12 PM
