587,374 active members*
3,669 visitors online*
Results 1 to 14 of 14
    May 2006
    86
    Measurement Please
    Howdy,
    As you may know I am designing and building a base for a soon to be ordered Tormach 1100 Series 3.
    A friend just pointed out to me that the dimensions I have been using from the Tormach web site are for a Series 1.
    So if one of y'all would be so kind, I'd really appreciate two measurements. See attached drawings. One is the measurement from the centerline if the mill to the outside of the electrical cabinet. The second is with the table all the way to the left. The measurement from the centerline of the mill to the left end of the table.
    Since I am currently space limited, these two dimensions will allow me to make sure my base is big enough to fit the mill and its operating envelope, but not waste any floor space.
    Thank you very much,
    kr
    Attachment 224458 Click image for larger version.
    http://www.parmarng.org/freeidaho/default.html
    http://xlforum.net/vbportal/forums/showthread.php?t=999415
    May 2006
    86
    Please
    Nov 2013
    402
    I'd help ya out, but I have the 770.
    Sorry.
    May 2006
    86
    Russ,
    Thank you Sir! I appreciate you.
    I know everyone has plenty to do without helping a newbie. But someone will help when they can. That is the best part about this forum.
    kr
    Jun 2008
    1082
    I think this document will give you your answer...
    http://www.tormach.com/uploads/8/D40...sions-pdf.html
    May 2006
    86
    Hirudin,
    Thank you. That is the document I started with, and it was pointed out to me that it is for a Series 1. I know of some things that have changed since that drawing was produced, but I don't know all the things that have changed. The dimensions might be fine, or they might have changed. I just don't want to trust it since I'm committing several hundred dollars in material. If I didn't need the absolutely smallest sized base, I'd just add some fudge factor and call it good. But I am jamming yet another big thing into my one car garage space, and it must be as small as possible.
    So I'd like actual measurements of a Series 3.
    Thanks again,
    kr
    Jun 2008
    1082
    Ah. I thought that seemed too easy.
    I'd do the measuring for you as well, but I don't have one either.
    May 2006
    86
    Hirudin,
    Thanks for trying.
    kr
    Nov 2013
    402
    Hey, you sound just like me.
    So far I have my PCNC-770, surface grinder, Kennedy 3-tier toolbox, 12x36 lathe, workbench, welder, Millrite mill, 60-gallon compressor, and my wifes washer/dryer all crammed into my 1-car garage.
    I'll find more room if I need to!
    Jan 2012
    714
    Facing the machine, Series 3
    39" left side center to the absolute end (e stop)
    26 1/4" right side to the e stop
    The left side on the series 3 has a cast cover over the stepper that extends beyond the stepper a couple inches. I dont think the earlier machines had this cover over the X axis stepper motor.
    mike sr
    May 2006
    86
    Mike,
    Thank you so very much. The left side measurement is exactly what I need. The 39" measurement is quite a bit different than the Series 1 dimension of 36.25". Using the Series 1 measurement would have been very bad for me.
    The right side measurement needed is from the center of the mill column to the outside right edge of the electrical cabinet not counting the hinges, mains power disconnect or 4th axis connector.
    Thank you again for taking the time to help a newbie ! ! !
    kr
    PS: when I get up and running I hope to be able to help others, instead of just ask dumb questions.
    Jan 2012
    714
    27 3/4" right side center of the machine to the outer edge of the cabinet proper (excluding hinges)
    mike sr
    May 2006
    86
    Mike, You just made my week. Thank you Sir ! ! !
    kr
    Jan 2012
    714
    Youre welcome sir, good luck on your project!
    mike sr
  1. How do I re-edit a measurement once I go to 3D???
    By BrassBuilder in forum Uncategorised CAD Discussion
    Last Post: 01-17-2014, 04:01 AM
  2. Tool Measurement
    By afrodyzjak84 in forum SIEMENS -> GENERAL
    Last Post: 10-29-2012, 08:44 PM
  3. Need a quick measurement
    By Vogavt in forum Benchtop Machines
    Last Post: 09-13-2012, 08:07 PM
  4. Tool Measurement B
    By oldgoat in forum Fanuc
    Last Post: 08-31-2011, 07:44 AM
  5. 0.01 mm Tool Measurement
    By Leha_Blin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2009, 06:04 AM
