587,584 active members*
3,806 visitors online*
Results 1 to 11 of 11
    Jun 2010
    Mechanical Engineer Needed
    I have a machine idea, and I need someone to design it. I’m looking for a good mechanical engineer to help me with the design. They need to be able to take my concept and turn it into a working machine. Does anybody know of anyone? The machine in mind will be a 2 axis machine maybe 3 depending on the design. The machine in mind will be like one of those plasma steel plate burning tables.
    Mar 2006
    489
    What can you afford for hourly rates?
    Paul
    Dec 2003
    24220
    Also a design such as that crosses at least two disciplines, mechanical and Electrical/Electronic.
    Al.
    Albert E.
    Jun 2010
    What would designing something like this go for. I'm in the steel business so i work alot with structural engineers, but i've never worked with a mechanical engineer. So i have no idea what mechanical engineers work for.
    Dec 2003
    24220
    What is the machine envelope? size?
    Can you give a rough idea of the application?
    Al.
    Albert E.
    Mar 2006
    489
    Do you need an engineer or a designer?
    Jun 2010
    The machine size in mind would run around 25'-0 Long x 3'-0 Wide x 4'-0 tall.
    The machine will be on the same basics as a plasma table use for cutting out steel plate shapes. Everything from designing the machine to designing a user friendly operator selected input interface to control the machine will be needed.
    Jun 2010
    I guess i would need both. I just have the idea now i need someone or a firm to turn it into a working machine.
    Jun 2010
    Machine Development to Full Function
    Hi Prosteel
    I'm in UK but my company more or less exclusively make 1 off special purpose machines - always with custom interface and usually based on customer's own ideas.
    Cost depends on lots of criteria - but happy to talk about it (anytime BST 9-5) to start you off.
    Dennis
    Jun 2010
    Hey DiscoDen
    Are you familiar with plasma steel plate burning tables? My machine is very similar to this, but the size and the type of material that it will cut is the only thing that would be different, also a friendlier user interface. Do you have a web site that I can visit?
    Jun 2010
    Well done USA - just seen your team play a fantastic match back from the dead at half time - brilliant!! and I'm not even a footie fan.
    Sorry Prosteel we do have a website www.abbotsburyengineering.com - more or less all work we do comes by personal contact or recommendation but contact details are there if you need them.
    Dennis
  1. Mechanical Engineer Needed
    By prosteel in forum Employment Opportunity
    Last Post: 07-11-2010, 08:33 PM
  2. Mechanical engineer or good machinist NEEDED
    By cnc2 in forum Mechanical Calculations/Engineering Design
    Last Post: 10-25-2009, 10:28 PM
  3. Mechanical engineer or good machinist NEEDED
    By cnc2 in forum MetalWork Discussion
    Last Post: 10-14-2008, 12:15 AM
  4. Trainee Engineer(Mechanical) Needed In The Gulf Countries
    By gina2010 in forum Employment Opportunity
    Last Post: 02-03-2007, 09:55 AM
  5. Trainee Engineer(Mechanical) Needed In The Gulf Countries
    Last Post: 02-02-2007, 05:59 AM
