587,187 active members*
5,269 visitors online*
Results 1 to 7 of 7
    Jul 2009
    Meldas 300 Data Protecting
    I have a MHI lathe that the battery went dead and im tring to get it going again. I have all the steps to do so but when i get to the format part in the data I/O erase screen it doesn't let me even curser over to type in format. It gives me a data protecting alarm. I have found edit lock C and B both are off.
    I have been told that edit lock A is on witch should be a key switch but there isn't one on the machine. I have also talked to Mit. and they have told me I can change Y238 bit to 0 and that should do it but it won't (or I don't know the proper way to change it) let me do that either. please help
    Jul 2007
    284
    You can change Y238 to 0 through the PLC I/F page. Under DEVICE type the address (Y238), under DATA type 0, and under MODE type 2 and then try to format. Do not power off and on before formatting as this will change Y238 back to a 1.
    Jan 2012
    Machine parameter selection
    Press the {PLC-I/F} menu key on the diagnosis {DIAG} menu
    Set 1001 into DEVICE {}
    Leaves DATA {} blank
    Set M into MODE {}
    Press the {INPUT} key
    THIS SHOULD DISABLE THE DATA PROTECTING
    To return to the user parameter display, either switch the power ON and then OFF once or proceed with the following operation:
    Set U into MODE {}
    Jan 2011
    350
    DATA PROTECT KEY 1
    M31OM,L : Y1B8 Y338
    M320, 330, 335 : Y238
    M330HL : Y238
    DATA PROTECT KEY 2
    M31OM, L : Y1B9 Y339
    M320, 330, 335 : Y239
    KEY2 M330HL : Y239
    DATA PROTECT KEY 3
    M31OM,L : YIBA Y33A
    M320, 330, 335 : Y23A
    M330HL : Y23A
    So make sure to take care of all three signals. Also, I think they should all be set to "1" for not protected, and "0" for protected. Cheers.
    Oct 2013
    27
    Re: Meldas 300 Data Protecting
    Yo!
    I'm in the EXACT same boat as you, on a MTC10-B lathe. Did you ever figure out how to get through this hurdle? I've talked to Mitz, went step by step through their process, only to be met with the same "DATA PROTECTING" alarm. Kinda sucks sack because the machine is super nice with parameters mostly intact as the only alarms are Z56 FIX_P REENTRY and Z70 ABS ERROR being displayed.
    Hudley Stungwell
    Oct 2013
    27
    PLEASE,
    If anyone can point me in the right direction it would be greatly appreciated. This is an outstanding piece of equipment that I am not able to utilize because of this issue. These are the only two alarms showing, and it appears that all of the parameters are actually still intact; based on the paperwork with the machine.
    Dec 2003
    I have suddenly the same message on screen. Cannot edit program, nor create new program. Machine was/is running, making same part it was making before the error showed up, holding same tolerance. The key lock in front on control makes no difference whther it is in off or on position. ALmost to end of this run, will need to program new part soon. Any ideas?
    Meldas L3 control
  1. How to transfer data using RS232 step by step in mitsubishi meldas 500?
    By godzila in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-27-2019, 11:47 AM
  2. Converting cloud point data from 3d scan to usable rhino data
    By LuthierWizard in forum Musical Instrument Design and Construction
    Last Post: 04-16-2014, 02:25 PM
  3. Meldas 520M rs-232 DNC data transfer issues
    By L98FIERO in forum Mitsubishi controls
    Last Post: 07-20-2012, 12:20 PM
  4. Protecting a 320
    By Keyes in CT in forum Gecko Drives
    Last Post: 06-29-2009, 06:13 PM
  5. Protecting MFD
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 12-21-2006, 12:00 AM
