600,674 active members*
3,193 visitors online*
Results 1 to 9 of 9
    Nov 2005
    43
    Meldas M3 - HELP - E50 file err 18
    My book is not too clear as to what I need to do with this error. Does anyone have any suggestions?
    Dec 2003
    24235
    I have never seen that one, but the info I have says that editing and I/O cannot be continued and to contact Mitsubishi service and give the classification number of the error (18).
    Does it occur on program editing or download?
    Al.
    Albert E.
    Nov 2005
    43
    Seems to be a file saving issue. Do you know how to reformat?
    Dec 2003
    24235
    I have had similar cryptic messages to contact Mitsubishi and it has turned out to be a defective eprom, identified by the classification number, and they sent out a new set for installation. Do you have the number for Mits. Chicago, you can usually get some one rightaway, (Unlike Fanuc!!).
    Al.
    Albert E.
    Nov 2005
    43
    Zeroing out Dynamyte 4400
    When I zero out the X,Y and Z axis, I am not able to move them after they reach their home positions. Do I need to enter in the data somewhere? Presently I select Zero Home and push each axis button. All three home buttons light up, then I can do no more.
    Mar 2003
    765
    Sounds like the soft limit parameters need to be re-set. You can check these in the process parameters.
    To reformat the program memory:
    Go into the machine parameters. Let me know if you need instructions on doing this.
    Set parameter 1166 fix_p to 1
    Go to the program erase page. Type the word 'FORMAT' in the second set of brackets and press <input>. Like this:
    ( )(FORMAT )( )
    The control will respond with 'ERASE COMPLETE'.
    Go to the Input page and type the number 4 into the first set of brackets:
    (4)( )( )
    Press <input> and the control will load in the canned cycles.
    Turn the control off and back on again.
    Nov 2005
    43
    Just wanted to touch base and say thanks to everyone. I am now working on the DNC using the free one that is talked of. That's today's project.
    Thanks Again
    David
    Dec 2020
    Quote Originally Posted by MetLHead View Post
    ( )(FORMAT )( )
    (4)( )( )
    Hello, my name Herin.
    Sorry I cant find the "ERASE" softkey/button in "IN/OUT".
    My controller is Meldas 530, I want formatting the memory but I can't find the "ERASE" button on that step.
    Anyone can help?
    Feb 2018
    8
    Quote Originally Posted by Herin552 View Post
    Anyone can help?
    I have the same....Did you do it? Can you help?
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. Need a file turned into a dxf file for a project
    By Guitarflyer in forum MetalWork Discussion
    Last Post: 12-05-2013, 12:31 AM
  3. Convert DWG file to DSTV file
    By benamer in forum Community Club House
    Last Post: 07-02-2013, 02:34 PM
  4. Call file as variable from within a file
    By CaptainVee in forum LinuxCNC (formerly EMC2)
    Last Post: 12-29-2012, 08:23 PM
  5. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
