603,960 active members*
3,770 visitors online*
Results 1 to 4 of 4
    Jan 2009
    memory card problem on robodrill
    Hi, i have just purchased a 1999 robodrill and the onecnc 4 axis package to machine some small 3d work, problem is the robodrill wont accept the flash card i use on the oi control on my lathe. The robodrill control is a 16im (b0f1), i have tried my 2G and bought a 512MB card but it wont read them or format them. Any help would be great. I have read about the smaller ata flash cards is it worth giving these a try? and where can i find one?
    Many thanks,
    Sam
    Jan 2009
    52
    SRAM Cards
    Early i controls (16ia, 18ia) could only use SRAM cards. We were told by GEF that putting an ATA Flash in the original units could damage them because of the 3v/5v difference in the cards. I have tested some SRAM cards from Epson (can't get them anymore) and Vikant Corp. model SA5002-P. They work fine. The Sram is more expensive but they work.
    As far as the smaller flash card i believe you mean a Compact flash cards. you can use them with an adapter (ATA adapter) in a newer Fanuc control.
    Regards,
    Feb 2007
    10
    Quote Originally Posted by aimcnc View Post
    Many thanks,
    Sam
    Sam,
    We have a '00 Robodrill T14iAL and over the years we have tried all sorts of memory cards and mocrodrives on it. You'll need to use a smaller CompactFlash card (I assume you have a CF-PCMCIA adaptor). The Fanuc 16iM-A control can only handle cards up to 256MB. I have a small stash of new 128MB cards that I hide in a supply cabinet so that we'll always have them in case the flash card manufacturers stop making them.
    Interested? I'll sell you one for cheap.
    -S
    Jan 2009
    Hi, thanks for the replies,
    Shibi, i bought a 128MB Scandisk CF but that didn't work either. After a lengthy conversation with GEF i found the very early 16i controls do indeed use Static RAM cards (spot on gwiz) Managed to find an 8MB pretech card for £180.
    Next problem........The new laptop i bought to run the cadcam software had an express card slot, not the pcmcia. So i had to buy a omnidrive SRAM reader/writer (£350) then had problems running it with vista. Nightmare.
    Sods law the first 3D program was 9.5MB
    After all this i found my robodrill has the remote option (i was told it didn't!!!!) so i can just run it from my old dnc software.
    Suppose you live and learn, just wish my mistakes weren't so expensive!
  1. Mori seiki MV40E memory card problem
    By v.sundermoorthy in forum Mori Seiki Mills
    Last Post: 04-20-2009, 08:35 PM
  2. memory card
    By rajanvadakkepat in forum Computers / Desktops / Networking
    Last Post: 08-26-2008, 07:54 PM
  3. memory card read problem with 0iMC
    By jhartleyjr in forum Fanuc
    Last Post: 05-30-2008, 05:00 AM
  4. Memory Card Cnm 1b
    By avaitsis in forum DNC Problems and Solutions
    Last Post: 07-27-2007, 09:45 PM
  5. Memory card
    By M-man in forum Fanuc
    Last Post: 07-17-2006, 09:00 PM
