587,189 active members*
2,560 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Metal milling machine 600x400x500 with ATC
Results 1 to 9 of 9
    Hello,
    We have been deciding for a long time whether to remodel old used machines (CNC ones) or to start our own construction. In the end, the building itself won. There were more reasons. Firstly, the fact that all commercial machines are made for larger spaces and, for example, my garage is only 2 m below the ceiling and nothing can fit there. The second problem is the electrical connection. I only have 230V, which allows me to use only a 3kW spindle motor.
    So I built the first, then the second ... fifth machine until I came to the conclusion that this is the right solution for me.
    The machine, including the complete cover, is only 2 m wide, 1.6 m deep and 2 m high.
    Originally, the machine was a replacement for the Tormach 1100MX, so I did not have high ambitions. According to the first tests on the prototype, however, it is much stiffer with a minimum of vibration. When I simulated it in all possible ways, I realized that I was one line better than Haas DM / DT, which pleased me.
    The construction is a prefabricated metal (naturally aged S355) supplemented with polymer concrete filling to improve vibration damping.
    Due to the maximum vibration damping (I live in a terraced house and the neighbors hear everything), the machine is standing on a rubber block. It can be replaced by a classic flange with adjustable legs.
    The headstock is designed so that it can be tilted by 90 degrees. and thus comfortably mill from the side. After digging, the workspace is not limited.
    Working space is 600x400x500mm. When using an ATC spindle and umbrella tool magazine, Z is limited to 400mm. There is 475mm between the table and the bottom of the basket, so if something wet is done, the tools will be pulled out of the magazine and there is such space available.
    The headstock has a base of 150mm drilling for an electric spindle of 7.5 kW / 9-18000 rpm. This is the ideal spindle for working with aluminum. Other spindles can be installed. I have a choice of three types of headstocks. One as you can see, the other for electric spindles with a square cross-section and then for the classic combination of BT40 + 5.5 kW servomotor.
    Rapid traverse is 45m / min. on all axes. The headstock is partially balanced by an air cylinder. The linear guide is from TBI size 30mm. Screws also TBI with double nuts OFU3210.
    Control is currently on Mach4, but it is full of other options.
    What do you think about it? What do you think is wrong, what do you like?
    It is an amateur machine that has to compete with SkyFire, SYIL or Tormach. For hobbyists, for such home milling. But it is also possible to shape, turn or grind flat.
    Thanks for your feedback.
    Jul 2018
    6458
    Re: Metal milling machine 600x400x500 with ATC
    Hi Rosco - I can see the long hours gone into this one! Well done. How are you going to align the rails? Are the pads going to be machined? Has it been built yet? Peter
    Hello,
    all bearing surfaces are finely milled and ground by my own method, so that flatness up to 0.02 mm / 1000 mm is guaranteed.
    It wasn't easy, but I didn't go the way. Not commercial
    Very nice design.
    Quote Originally Posted by mrosconi View Post
    Hello,
    Videos from the simulations can be found at: https://www.facebook.com/MrosconiTech
    I extended the Z axis by 100mm downwards to offer more range when machining in the horizontal position of the spindle. When all the tools are pulled out of the magazine and a face cutter of sizes d63 and larger is used, I am able to machine to 400mm (Z) in height and 370mm to depth (Y). The X axis is not limited, so straight 600mm. At first I thought I would have to leave with an umbrella or lift it, or when used in a horizontal position, just turn it somehow, but it doesn't make sense. So definitely the working space in the vertical direction with ATC is 600x400x400 (with a reserve of 50mm in Z) and 600x370x400 for horizontal machining with the need for an empty tool magazine.
    Attached Thumbnails Attached Thumbnails Mrosconi No.1 - FrameKit - Servo 1kW - Spinde ATC 7,5kW - cover - ATC -11.jpg
    This is what the first prototype looked like. Terror and horror, but fully functional. Here I understood that there would be a problem with the obscuration of the Y axis between the column. In the end, I had to put a classic bellows. Then the remodeling began until the machine became something else. Due to the cover of the back of the Y, a very new project was created But it will be better!
    Aug 2006
    673
    How's that spindle working for you? I've been thinking about getting one for a project of mine as well.
    Nice build, it's a pretty substantial machine right there!
    Dík.
    Za peníze si myslím, že v?eteno je naprosto v po?ádku. Mám dva. jeden je s vrtáním BT30 a druhý s BT40. První má kuli?ková ložiska s kosoúhlým stykem a je omezena na 6000 ot./min a druhá, BT40 má kuli?ková ložiska a 8000 ot./min. Tak tam píšou. Stále jsem m?l tento malý BT30 1,5 kW, ale byl docela slabý. Doporu?uji verzi 3kW.
  1. Metal milling machine
    By moadi in forum Want To Buy...Need help!
    Last Post: 01-21-2019, 10:11 PM
  2. Light metal milling machine
    By khoac3 in forum Vertical Mill, Lathe Project Log
    Last Post: 10-29-2016, 08:15 AM
  3. Metal CNC Milling Machine
    By endlasuresh in forum Benchtop Machines
    Last Post: 04-26-2016, 03:39 AM
  4. Milling machine for metal shoe mold
    By DhakaMould in forum Chinese Machines
    Last Post: 04-25-2014, 02:26 AM
  5. metal milling machine conversion
    By i-make-robots in forum Uncategorised MetalWorking Machines
    Last Post: 06-02-2011, 08:57 AM
