Ok well first off i appologise for possible not putting this in the correct section but you guys have so many its hard to choice especialy with such a broad category of a qeustion.
QEUSTION/PROJECT: Ok i am just wondering what method i should use for my project...what i am trying to do i produce my own single axle( one whole axle all the way through the truck) "tech deck trucks"(small 96mm long skateboards, if you didnt know)...
i know and have partialy researched casting (sand,gravity, pressure etc) and all but becuase of the extremely small size of these trucks i am wondering the best method for production (possibly milling or other??).. thank you, your help is very appretiated... and if you dont know what a skateboard truck looks like heres a referance image
(life size skateboard truck):
the only parts i will need to produce would be the hanger(main top part) and the base plate(main bottom peice) none of the nuts, washers or bushings are needed...i would need to know how to thread the axles though.
PS: the "truck" is a two peice device(hanger, base plate) so they would most likely be casted/produced seperatly..
I am very new to metal work/machining so go easy on my please...i would like to learn and this project is very important to me. Please just tell me the best possible way to produce my product.
Thanks, NOODL3
EDIT: i couldnt put pics in my topic so if you need refrance pics check the attached files
