603,953 active members*
3,659 visitors online*
Results 1 to 7 of 7
    Oct 2006
    586
    Metric Threads
    Just have a question probably a dumb one but never the less a question. i dont do much metric threading and when i do i just kinda fug my way through it. i though it was about time i asked how do you convert or figure out your TPI on a metric thread the one i am doing today is a M18 x 1.5 6g
    thank you
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    May 2006
    265
    25,4 / metric pitch = TPI....
    THread dia -(0.1*metricpitch) /25.4 will give you a good dia of shaft before threading..
    Take 18-1.5 to get bore dia for ID thread.
    Jul 2005
    12177
    Another way to calculate pitch is use 1.000mm = 0.039370" so 1.5 mm is 0.059055".
    Oct 2006
    586
    Quote Originally Posted by Geof View Post
    yeah it took me a min. but i figured it out then take 1. / .059055 = your tpi
    and M-man's way works to. thanks i appreciate it
    Oct 2006
    586
    ok i come up with a diferent answer doing it M-mans way the way you show it comes up 16.949 tpi his it comes out 16.3333 the 1.5 / .03937 is the way i origanly went with
    Jul 2005
    12177
    My calculator gives 25.4/1.5 = 16.933333
    1.5 * 0.03937 = 0.059055
    1/0.059055 = 16.933367
    If you want to get really precise the 0.03937 is only an approximation. It is actually 1/25.4 = 0.03937007
    So 1.5 * 0.03937007 = 0.0590551
    1/0.0590551 = 16.933338
    Oct 2006
    586
    I see i was not finishing the .059055 i was just using .0590 that makes more cents
    thanks Geof
  1. The Metric System
    By single phase in forum Hypermill
    Last Post: 04-22-2023, 12:24 AM
  2. Rigid tapping metric threads
    By msomerville in forum Milltronics
    Last Post: 07-11-2007, 03:47 AM
  3. Looking for a Metric equivalent to ACME threads!
    By widgitmaster in forum Linear and Rotary Motion
    Last Post: 02-11-2007, 03:12 AM
  4. DRO - Metric or Inch
    By DJ Morrow in forum CNC Machine Related Electronics
    Last Post: 11-15-2004, 09:06 PM
