603,907 active members*
4,833 visitors online*
    Jan 2016
    6
    Unhappy MG205 "Check Tool" Error
    MG205 with ATC is having trouble after tool change. Chuck appears to open / close just fine, but it's now consistently displaying "check tool" & won't run job. Is there a sensor I can check?
    Recent maintenance that may or may not be related:
    -Swapped out the chuck open, dust boot, and TC blast pnematics solenoids - all appear to be working just fine now. Last week the TC blast was staying open all the time
    -Re-lubed the tool grabbing portion of the chuck with metaflux
    Thanks in advance for any help!
    Jun 2010
    480
    Re: MG205 "Check Tool" Error
    Did you have this error before you did this maintenance. Which spindle do you have?
  1. Replies: 3
    Last Post: 09-11-2020, 05:12 AM
  2. Replies: 0
    Last Post: 02-05-2016, 12:22 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Bridgeport 760\22 Heidenhain 370 "error 2 tool def"
    By JNFSWE in forum Bridgeport / Hardinge Mills
    Last Post: 08-26-2008, 07:45 PM
  5. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
