588,064 active members*
4,866 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > MH 40 hmc machine with MORI SEIKI MSG 501 system gets hanged
    Dec 2007
    we have mori seiki MH 40 hmc machine with MORI SEIKI MSG 501 system.mACHINE HAS H 111 ,H211 A068B-6096-H304 DRIVE FOR THREE AXIS
    tHE OLD DRIVE had Sr nos A20B-2100-0260/09C control card but when we replaced this machine with new drive with similar control car but with version 11d ie A20B-2100-0260/11d the system get hanged .Fanuc supplied us with file 9090r.mem for loading to set this problem right but again system is getting hanged with error message
    1 5138 FSSB: AXIS SETTING NOT COMPLETE
    2 100 : PERAMETER WRITE ENABLE
    Can you sugest solution for removing hang and error 5138 problem
    [email protected]
    Feb 2009
    6028
    Think you forgot to install the terminator jumper on the drive..
    The drive card is fine, just a different revision #.
    Dec 2007
    Quote Originally Posted by underthetire View Post
    WE HAVE DONE S1 S2 setting for terminator jumper on drive but the problem is same .
    The sys gets hanged and no key works .
    Any more suggestion welcome
    [email protected]
  1. mori-seiki system 6t
    By libbey in forum Fanuc
    Last Post: 06-08-2013, 09:59 PM
  2. Mori Seiki SL-3 with fanuc system 6t
    By cmo in forum Mori Seiki lathes
    Last Post: 01-19-2012, 01:57 AM
  3. MORI SEIKI MV JUNIOR system error 912- FANUC O-MC
    By janez9 in forum Mori Seiki Mills
    Last Post: 05-16-2011, 01:53 PM
  4. Mori Seiki AL 2 Fanuc System 10TE
    By krfrea in forum Mori Seiki lathes
    Last Post: 09-16-2010, 03:44 AM
  5. Mori Seiki MF-T6 System Variables
    By EvilScooby in forum Uncategorised CAM Discussion
    Last Post: 06-13-2003, 01:32 AM
