587,999 active members*
5,110 visitors online*
    May 2007
    20
    M&H Spindle Probe ?
    Trying to use a M&H probe in "auto" mode on a DMC 3-axis mill. The problem I'm having . . when we call this probe out in auto mode with tool change "T1M6" the machine just hangs up. If we call the probe out in MDI mode (have probe in spindle prior to running program) then run the same probe program it works fine.
    Anyone experience this problem? A possible solution?
    Thanks, Sheldon
    Apr 2002
    5003
    Dependent of the machine, the Probe must have a definite Tool number, T9, T99, T999 or so.
  1. spindle probe error
    By kendo in forum Haas Mills
    Last Post: 04-13-2012, 06:36 AM
  2. omp 40 spindle probe help please !
    By rusty1979 in forum Haas Mills
    Last Post: 02-08-2011, 04:27 PM
  3. Spindle Probe
    By Ashish B in forum CNC Machining Centers
    Last Post: 04-17-2010, 10:33 AM
  4. My probe is stuck in the spindle, need m19
    By crazyneosimpson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-24-2010, 08:12 PM
  5. Replies: 6
    Last Post: 06-12-2008, 07:24 AM
