Hi all
I have a small CNC machine which i use to cut mainly sheet alu.
Recently I've been dabbling with engraving with it and I am pleased with the results.
however unlike my normal cutting this requires a true flat surface, especially as I plan to engrave over a 500x500mm area.
I have been getting quotes for a 540x540mm piece of MIC6 Aluminium which I figured would be the best type to use.
My question is thickness, would 10mm suffice?
I have 3 support struts underneath this piece at equal spacing that would run the full length of the piece
Would 10mm keep its flatness across these gaps? Or would I be better with 15mm or 20mm?
Thanks for any help.
Tom
